X2 on that Selkirk cap. That is what comes in the DT venting and it works great! Even has a nice bug screen mesh!Mommyof4 there is a cone cap termination cap for the line of venting you have: http://www.northlineexpress.com/3-selkirk-vp-pellet-vent-pipe-exit-cap-3vp-ec-3vp-ec.html but make certain that you can use it where your vent exits, sometimes just using a 45 degree elbow pointed down is enough.
I haven't seen to many jet caps with dimensioned pictures or diagrams Bioburner.
Thanks for the link Smokey. That gave dimentions or enough of one for me to get proper cone angle etc
The link provided by Smokey gave a dimension that I can work off. Will cut one or two if I have enough tubing and weld one next week when the outside temps are supposed to get above freezing. Finally, at or above normal temps. Maybe find the cell phone I lost while moving snow.How quick were you planning on starting fabrication? Meant to get out there today to pull it to get dimensions and pics - Sorry didn't happen. Have to get pallet of pellets in AM but can try to do it in the afternoon...
But does the tip provide a venturi air volume boost or just look good. I had a tip on my 1 ton that would make the turbo system whistle. Would make the dogs howl.I made this one to give some clearance from snow dropping from upper level. In doing so, I had some fun with a diesel exhaust tip.
https://www.hearth.com/talk/index.php?threads/In-All-Seriousness....-A-Safe-Termination-Cap?.81609/
A horizontal pipe won't hold water very well but snow will get in if the stove is not running. But if its snowing I would bet the the heat is on. A direct wind can mess up a vacuum sensing system if the pipe is close to the house. My Bixby would have a fit with a direct wind till I extended the pipe another 2 foot away from the house. If you can gat away with a simple 45 downward elbow it would probably the least problematic and easiest to maintian. Just cover it in the off season to keep out the unwanted pests.Will the rain/snow affect the venting if it gets in?
A horizontal pipe won't hold water very well but snow will get in if the stove is not running. But if its snowing I would bet the the heat is on. A direct wind can mess up a vacuum sensing system if the pipe is close to the house. My Bixby would have a fit with a direct wind till I extended the pipe another 2 foot away from the house. If you can get away with a simple 45 downward elbow it would probably the least problematic and easiest to maintain. Just cover it in the off season to keep out the unwanted pests.Will the rain/snow affect the venting if it gets in?
I have a horizontal exits on my stoves and am trying to get someone to get me some dimentions on a jet cap that I can build out of heavy stainless instead of the over classed beer cans that are sold. Your termination horizontal or vertical? Will see how fast this thread goes down hill now that I got beer included![]()
That seems differant than the one Smokey linked to. More like the one I had seen somewhere. Maybe a picture at your leasure. I know others are probably curious. ThanksGot some dimensions from our cone termination cap for 3" pellet pipe:
Overall total length 10"
Overall length of cone: 6"
Diameter at base of cone: 5 1/2"
Diameter at top of cone: 3 1/4"
Three support tabs approx. 1" from base of cone
Internal pipe extends beyond base of cone and has screened end but didn't try measuring as stove was not shut down! If you want these, let me know and will try for shut-down earlier in the day.
The one I had seen posted somewhere I thought looked long and sexy. Like a old firemans nozzle or the exaust of a fox jet engine or maybe something Lady Gaga would wearThe one I linked to was for a particular vent system and is a jet cap. There are tons of termination caps just about every maker has several for each type of termination orientation.
The one I had seen posted somewhere I thought looked long and sexy. Like a old firemans nozzle or the exaust of a fox jet engine or maybe something Lady Gaga would wear![]()
