Looks good Noah!
I really like your distribution setup. Is that controlled with a zone valve controller, or only based on the TRVs on each leg? If so, do you just turn on the alpha manually and let it run for the duration of the heating season?
I see you didnt put the boiler up on a stand at all. How are you handling pulling ashes out of the combustion tunnel?
Another Varm - awesome! Congrats on the fire - looks great!
How will you be finishing the DHW? An indirect tank?
Nice setup Noah, I do like the non-electric ZV. Great installMake sure you put the pics on Gass's boiler pics thread
TS
What did you use for tank insulation Noah?
Yeah,that's about it, switch on the alpha and ivalve and let the TRV's determine the flow thru each loop to maintain the setting. Position 3 is about 68 degrees, which I had the living room and kitchen set to on Christmas. Eleven people in those rooms and it didn't take long to see the flow stop completely in both loops. I love em so far.
Ahh the stand. I wanted it but it really made my plan for thermosiphon more difficult and plus my wife wants some shelf space above the tank for drying green ware when we get our pottery biz running again. So I need to find or make the right trey that can live right under the boiler, between the two front bricks. I have to kneel down for that and of course to look at the awesome flame!
Noah
Thanks Maple.
I will probably use my fairly new 40 gallon electric water heater with a side arm and rely on thermosiphon only. It will be located directly above storage, now it is on my basement floor using electricity-Grrr.
I believe you're using a side arm? How is that working for you? What kind of scald valve are you using?
Noah
So the iValve adjusts the supply temp based upon the OA temp, correct?
Is that your secondary chamber in your avatar pic? Looks quite a bit different than mine - mines just a rectangular box.
That's a sweet setup you've got there - I would have more storage if I had the room.
That is correct. The ivalve is probably overkill but it basically guarantees the minimum flow thru storage. The main reason I installed it was because I went "cheap" with the lightweight plates and PERT tubing. They have a reputation of being noisy...tick...tick..with on/off type control. Pex-al-pex expands/contracts a lot less and would have solved the noise potential but I also chose to run my tubing 12"o.c. with the 9" plates so heat striping was a factor. Constant circulation with O.R. means no abrupt changes in supply temps and should even out the floor temps between the tubes. It works great so far.
Mine is all ceramic. If you take the 'round' metal part out of yours, that's pretty well what mine looks like - except all ceramic. I guess there are more differences than I thought there were in these. I'm hoping for a decent life out of mine before I need to replace - but I did get a set of spares when I got the boiler. I'd like to come up with something about the same shape of the nozzle I could just set in the nozzle hole to protect its edges from future erosion. I was thinking stainless or cast frying pan with holes or slots cut in the bottom until I realized it wasn't round but more football shaped. For now I just keep a good layer of ashes in the wood chamber.
Im going to order a replacement after this season, just to keep it on hand.
Do you ever have to worry about the pump deadheading?
