pearsall said:I just switched my vintage Jotul 118 for a 13NC tonight. Although I will miss the beautiful green enamel I feel I made the right decision when it comes to safety and efficiency. Thanks to Home Depot (and a warm winter) for cutting the price in 1/2.
Of course I am typing this with the toxic new stove smell and I'm sure there will be a learning curve with this new stove, but I think I made the right decision. . .
DrEvil said:I too had the fun adventures of a smog filled house and a nice smell of burning paint today![]()
I made the purchase and the stove is burning right now.
I do however have a concern...
I have been burning the stove since about 2 pm today (its now 1130) and I am having a hard time getting it HOT. I was light at first to bake the paint easy, but I tried to crank it up to shut it down for the night and its not liking that too much.
Here are the details to the best I can describe...
Basement level of a 2 story house.
Basement is unfinished at the moment.
Temp gauge reading 150 at the stack and when moved to the single wall above the stove it sits at 200 (Magnet mount no probe yet)
18" off the stove into an elbow then horizontal with a good pitch to another elbow then straight up the double wall
Burning "seasoned" Maple, Oak, and Birch. I have been adding some cut pallets to get it a bit hotter and it helps.
Stove is currently piped together with Oil furnace (It will be powervented and switched over in the spring)
Chimney has NEVER had wood in it until two weeks ago.
The stove stays lit and going just fine, but the heat level in the same room is not really impressing me. I do not have an OAK (yet) and had no problems with the previous NON air tight stove.
I find that if I keep the door open a crack it will get to about 300 but no higher. Unless of course I throw in a bunch of pallet wood. I am leaning toward the wood that I am burning however, It's rather odd that I cant get too much of a noticeable difference with the damper all the way open. I may be able to snap some pics tomorrow.
Roospike said:mike .......................
Besides expense of doing so why cant stove manufactures bake on the paint like everything else that is painted and sold of kind?
stoveguy2esw said:Roospike said:mike .......................
actually its more than just paint, paint is a small part of it. the biggest part is cooking the oil out of the steel. steel stoves are made from steel that arrives at the factory pickled in oil, a lot of it is actually cooked out of the steel during the welding processes, but most is still in the steel, only way to get it out is to heat the unit to a temp similar to what it reaches during a fire, and hold that temp for a couple hours, its just not practical to do so for us. we produce a couple hundred units in a given day. the kind of facility needed to cure the units would have to be immense. on the bright side, it only happens once, first good hot fire does the trick.
