I have really struggled with the Vigilant and this house, I replaced my old Vigilant(1979 short door) with a fresh one this year, the Vigilant I am using is a 1983 2 piece back model, it was fully dismantled, cleaned, reassembled with furnace cement, new gaskets, etc. yes I have read the manual front to back several times and have been using a Vigilant for my whole life, I will be 40 next month. I am burning mostly Ash, Maple, and Oak that has been split for 3 years, stacked and covered for 2. the chimney is a 7x11 rectangular flue with a flexible liner, so probably 6x10? and 31' from the thimble to the top ( yes it is very tall), I am heating a 2400 square foot log cabin build in 1977, its tight as log cabins go, but it is not a super tight house by any means. The issue I have is that I cannot get this thing to idle, theoretically I should be able to burn it in updraft mode, ( damper open, secondary air closed) and just use the primary air supply to regulate the fire, this is not the most efficient way to run the stove, but I should be able to do it. If I close the secondary air supply and close the primary, before long it begins to puff, and flip the primary flapper open, sometimes it even lifts the griddle. It will do likewise in horizontal burn mode (damper closed). My solution to prevent the puffing, smoking and sucking has been to bend a small piece of copper wire into a U shape and put it in the primary air opening so the flapper can't completely shut , this works well, but it will allow the stove to over fire unless you close the damper, even then sometimes we get what I guess could be considered a small chimney fire going where it burns off any excess creosote in the stove and stove pipe, it will run hot, 7-800 degrees for a period of time maybe as much as an hour, but usually it settles down after half an hour, I clean my chimney every year, and sometimes if I feel it needs it I bought one of those flexible rod with nylon string attachments for a drill with 30' of rod. I can pull the stove out and run it right up the thimble, I get a lot of sooty stuff and a few crumbles, but nothing you would call an excessive creosote buildup. Something I did do recently was to seal where the oval adapter goes into the cast throat, by checking around the stove with a lit long nose lighter I determined it was sucking a fair amount of air in through that joint, still even tonight, with a 350 degree stack temp and maybe an hour and a half into a horizontal burn, it decided to give a good puff, I opened the top and rearranged the wood inside and let it heat up a bit, so far its behaving again. this behavior is something I have struggled with for quite a while.
My dad has a Defiant Encore and an Encore that will go indefinitely just simmering along in updraft without ever engaging the damper. why am I struggling so hard with this Vigilant?
Any input here would be appreciated, I have considered making an adjustable disk with a small, maybe 5/16 hole, installed on the primary flapper so I can regulate the amount of bypass air that can get by even with the damper closed, I have also considered making something that would work like a valve in an ICE engine where as it pulled hard for air the valve would open allowing a small amount by. I feel like it is trying so hard to suck air through any orifice that it is literally pulling the damper door shut where it can't open even if it needs to until it finally manages a small explosion inside and then it pops the door open and takes a gasping breath.
