JohnDaileyNH
@Woodsplitter67 do you push your coals towards the back when you reload? The manual recommends doing so
Well.. this looks like it could be the problem.. Your air flapper is not open all the way.. this is an easy adjustment as described above.. literally a minutes timeThis is mine closed and then fully open. View attachment 316607View attachment 316606
So are 1000 - 1400 degree Cat temps normal and safe ? what should the stove pipe temp be when this is happening ? i also have the "operate Catalyst" prob and need a digital one for this year.
That is as far as the flapper will open. From the adjustment lever you can hear the flapper ting metal at fully open and at fully closed. When it’s fully open like the picture shows and I push on the flapper by hand it doesn’t open any further, something stops it.Well.. this looks like it could be the problem.. Your air flapper is not open all the way.. this is an easy adjustment as described above.. literally a minutes time
you could have the installer do it but from what you have said above your handy.. just make sure your flapper closes all the way.. do this with a COLD STOVE... What is the overall length of stovepipe you have
I have a short interior run to an elbow, through wall, then a 16’ exterior run. View attachment 316615
I knew that going in that a basement install could pose some challenges but my house was built in '59 and she's definitely not air tight so I'm not too concerned with a negative pressure issue, although it is a factor.
I'll try adjusting the flapper later today and see if I can get it to open further. Thank you for the time and advice so far. Very much appreciated.
Also, just to see if I'm crazy or not; where the elbow connects into the thru wall horizontal pipe, should that elbow be fastened to the horizontal pipe with the three screws, or should it sit there loose?
I’m surprised your little buddy hasn’t popped in to comment on this thread yet😂Its not a problem helping you out.. This is what this site is all about.. Were all friends here.. or at least most of us anyways..
I got the wrench to loosen the nut on the flapper, but there wasn’t much play with the wire at all. If I pulled the wire and tighten the nut or if I loosened the wire and tighten the nut it didn’t change the flapper much.
While I was down there I saw another area just above it. Any idea what I’m looking at?
View attachment 316678View attachment 316679View attachment 316680
