Variable speed pump vs three way valve
Medman
460
Sault Ste. Marie, Ontario
I'm just about ready to pick up the required pieces and parts for my primary and secondary loops. I have been reading on Taco's site and they suggest replacing the three way valve in the near-boiler piping with a VS circulator that has an external temp sensor installed on the return pipe.
Is there an advantage to doing this, other than for Taco to sell VS circs? It looks to be about the same for price for the pump or a Danfoss three way valve.
What do you think?
you may not need either
have a look here
https://www.hearth.com/talk/threads/20980/
where people talk about using simpler arrangements of bypass valves or bypass pumps to avoid the need for either a mixing valve or an (expensive) variable speed setpoint controlled pump
someone other than me will have to advise you on how to do it with an EKO, but I think Nofossil has the same boiler you've ordered, and has no 3 way valve nor a variable speed pump, and he's known for doing things well
