It won't last long at that price, I don't think. If it fits your heating needs, it's hard to beat that stove. It's easy to run, and Woodstock customer service is second to none.Lots of thinking on this one.
I was replying to 3650 on a stove price of $1500. The CL poster wants $700 because they cant continue burning wood due to allergies. I see a lot of mold etc on wood that people try to season in the shade of the woods.They are asking $1500? If you can get it for $700, great. I might go $900-1000 if I had to. Probably needs new gaskets, too, but the complete kit is only about $40. Gaskets, cat, they're maintenance items, that's why you get a used stove for a lot cheaper.
If you dont want it let me know where it is. I've had my eye out for an affordable one. The one I missed for $250 would have been a theft.
Get the gasket kit from Woodstock: http://store.woodstove.com/product.php?productid=16702&cat=276&page=1. I've never tore one down, just patched air leaks in seams and replaced gaskets in my SIL's Fv, but if you do it you can make the stove just about like new. I would think the toughest part would be the timing/logistics of getting the parts back together as you apply the cement to the seams. I also think you need to let the cement dry for a few weeks, but fire the stove to cure the cement within a month. I made the mistake of firing the stove too soon after I patched the seams. The "gasket cement/stove sealer" I used was thinner than "furnace cement," wasn't dry yet and boiled, leaving air bubbles in the cement.How hard is-are the stoves to take down? needs a total cleaning and couple parts and a new cat. Would like to install all new gaskets too. Blast and repaint of exterior metal too.
Wow, that is cheap. I guess that kit cost includes all the separate packaging, labeling, instructions etc. I think with the latest steel cat, you don't need the interam gasket either; Doesn't use the cast iron cat frame like the older cats.Looking at the list of gaskets and they seem very reasonable and I have lots of gasket adhesive. Don't think steel wool and a tube of cement is worth 20 that's in the kit.
Looking at the list of gaskets and they seem very reasonable and I have lots of gasket adhesive. Don't think steel wool and a tube of cement is worth 20 that's in the kit. Yes I am tight, just like a good stove should be. Will need to order new Cat, andirons and bypass plate. Everything else seems good but the paint on the iron and will blast everything and prime and paint that. Will end up with about 950 into the stove without labor and should be almost as new.
It's a sweet stove; Bring it along unless you're moving to Florida, if it's the right size for your new place. Just strap it to the top of the car with a couple bungees.My luck will be get it done and will decide to move south without firing it up.
