wondering if the high mass brick walls once warm will require such a heat demand.
Brick walls about 1ft thick up to the eaves, but it does have studs with lathe and plaster. The radiator pipes go from the crawlspace up the outside walls to the radiators on the second floor.
A couple comments...Mass, when insulated from the exterior, is a wonderful thing (which is why there's rigid foam on the outside of my frostwall/stemwall), but uninsulated mass still bleeds heat like nobody's business. Might work out in a few places where the sun always shines and it gets hotter than the house in the daytime, but on the East coast it's just a lot of square feet of a lot of BTUs/Hr/SqFt/DegF - 12" of brick might be all of R2.4 (or 1.2, depending on the brick.) A building with a perfectly insulating basement, a perfectly insulating attic, no air exchange and walls of 12" brick that was 18 ft high, 20 feet wide and 30 feet long would need 51,000 BTU/Hr to stay at 68 when it's 0 outside - or 102,000 using the more pessimistic number for R-value. Let it be bigger, it needs more.
You have a big advantage over the rest of us old house nuts, in that you actually HAVE wall cavities in which to feed wiring! Many of us are living in houses with plaster right on masonry for exterior walls, and planked interior partition walls. No wall cavities for feeding wiring! I still have the plaster on masonry for my exterior walls, but my planked walls were framed out with "new" plaster and lathe walls and ceilings sometime around 1800 - 1820. All of our wiring had to be installed in those interior partition walls, or run behind baseboards on the exterior masonry walls.All the wiring I can see has been updated from post and tube, but I've not been able to see everything yet. There still may be some post and tube wiring in the house and possibly in the walls.
... just be damn sure there's no live knob and tube in those wall cavities, first! This is apparently a major issue with blown-in cellulose in older houses.If there are stud walls in your new home have you considered having loose fill insulation blown into the stud cavities from inside the home? You wouldn't have to gut the house to do that, just patch the holes used to blow the insulation in through. The retrofit company could advise you I'm sure. Best of luck.
+ supply temps at avg temps and 180
at design temp then the benefits of large storage would be minimal and a buffer tank sized to minimize idling might make the most sense. Whereas if you can use 120 to 140
in avg temps you could reap the benefit of convenience that larger storage volumes can offer. Adding some radiators to be able to lower your supply temps could be a good investment, IMO but it could be a total PITA too. It all depends.I've been reading for a while, and have not been able to see anything similar to my situation.
I've a home that after insulation upgrades has a heat loss on design day of 98kbtu/h. Anyone out there using wood to heat a home with this large of a heat load?
thanks,
dave
You can get a stab at this by using 6050 btu/lb of seasoned (20%MC) wood. Find out, with your species mix of wood, the weight of wood one firebox load will hold, multiply lbs by 6050, and you have approximate total available btu's. Actual output to your heating load will be somewhat less because you also will lose heat from the boiler, plumbing and from the tank to the surrounding environment. Perhaps use 85-90% of available btu's as what you actually will get into your heated space.... but how do you figure out how much total heat it will produce on one burn?
Silly question, maybe... but are you dead set on a wood boiler? A more conventional boiler (oil, nat. gas) or furnace (propane, heat pump) paired with a wood stove (or two) has satisfied me, and my heat load is WAAAaaaayyyy beyond you requirements. This was not done purely for utility, but more with the thinking that, if I'm going to do all the work of felling, limbing, bucking, hauling, splitting, stacking, moving, and loading wood... I want to look at a pretty fire! No sense in hiding it in the basement, was my thinking.
