Hi,
Today, I picked up a utility trailer load of cut-offs from a local flooring company. This wood is the left overs after the company cuts the floor boards to length or removes defects. These flooring planks have been kiln dried, planed & routed and but are otherwise unfinished. The planks are 1" x 3.5" and the length varies from 3" to 16". From a quick glance I saw oak, maple and walnut. The company also produces hickory, ash, cherry, birch and beech flooring so those woods are likely in the trailer load as well.
We have a small supply of firewood from last year (about 1.5 cords) of maple & oak and an additional 1 cord from a maple tree we had cut down in the spring of '08. I know we'll need to buy some more regular firewood but I'm not thrilled with what's available. Yes, I put off getting wood until the last minute. I can get several more trailer loads of the flooring cut-offs for very cheap.
Anything I should keep in mind about using this cut-off wood? If I understand things correctly, the smaller the piece of wood, the quicker it will be burned. And so I'm pondering making some "logs" by gathering about 8 pieces of flooring planks roughly the same length, then fitting and stacking them so that they are 2 deep x 4 high which would give me a "log" with a cross section dimension of about 4 x 7. I could bind this together with wire. Maybe it's a dumb idea - I'm just brain storming.
