I'll have to post a pic of the multimeter I have. I can't get a reading to save my life. But the thing actually has some decent sharp probes on it. I'm probably using the wrong setting. Electrics at times confuse the you know what out of me. %-P
My meter has sharp probes too (so much so that I have drawn blood more than once when reaching for it in my tool pouch). But I could not get a reading by just poking them onto/into the surface of the wood. I had to drive a couple nails in, then it worked.Skier76 said:I'll have to post a pic of the multimeter I have. I can't get a reading to save my life. But the thing actually has some decent sharp probes on it. I'm probably using the wrong setting. Electrics at times confuse the you know what out of me. %-P
This sounds like an interesting idea. I have a craftsman dmm, what setting should I select. My initial attempt didn’t get me any reading at all.
I checked my hickory in the open meadow. Wood that I had split from rounds yesterday was 16-20 kOhms of resistance, which is off the charts on the USFS PDF. I’m guessing that this is about 40% moisture (or more).
Then I checked wood that I had cut and split into ~4-6” pieces (bigger than I would burn, but small enough to dry) in the late spring, early summer. I just covered this wood 2 weeks ago, and we had a rainy summer so it got a lot of moisture. A split was measuring about 350 kOhms. That would equate to ~27% moisture content (it’s off the chart, so I extrapolated). Then, I checked a 5-1/2” round - I split it in half and checked the moisture on the inside - 20 kOhms. This is essentially as moist as wood that was split a day before. Lesson learned - split the rounds as soon as possible. Luckily, I only need half this wood for next winter, so I’ll resplit rounds in the spring and restack.
DBoon said:Just checked some of my wood supply with a digital multi-meter to see if my moisture content is in the target range.
Cherry - 18 months old, spent half the time in a garage, half the time outside covered and in the sun half the day. DMM reading: 9 to 15 megohms, even on the inside of the split. Well under 20% moisture content
Sugar Maple - 18 months old, half in garage, half outside (like the cherry). DMM reading is 6-9 megohms, which equates to 16-17% moisture content.
Pine - 18 months old, stacked outside in sun and wind. DMM reading is 20-25 megohms, which equates to 15-16% moisture content.
Sugar Maple - 5 months old (fresh cut and split at that time). Stacked outside in the driveway, uncovered the first 3-1/2 months, covered last 1-1/2 months. DMM reading is 0.6 to 0.9 megohms, which equates to 24-25% moisture content.
Will have to check my hickory that is stacked in windrows in an open meadow, and now covered for the last 2 weeks. That was fresh cut and split this year, so it will be interested to see what that is right now.
DBoon said:FYI, here is the link to the referenced forest service document http://www.fpl.fs.fed.us/documnts/fplgtr/fplgtr06.pdf
As you saw, Cherry was not listed there, but based on the observation from someone else, and my own reading of the table, with few exceptions you are good to go if your resistance reading is 3 Megohms or higher. Hickory (which I have a lot of) is one of those exceptions.
In any case, my experience is that cherry seasons and dries pretty fast.
My previous post above was from January 2010. I just went up and checked the moisture content of a split about the same size as what I checked before, and on the same side of the pile. As before, I split it in half and checked it on the inside. The split was measuring 440 kOhms. That equates to 22% moisture content per the USFS document. So, in two months, moisture content has gone from 27% to 22%. This wood is definitely going to be ready to burn next winter.
Not sure what your issue is?
You know it's wet, and your dmm numbers reflect that.
Resistance increases as the wood dries, and the number will increase
