Uses for ash
It works pretty good. It blends in when it rains and the grass seems to be greener.
Construct an ash hopper and you can make potassium hydroxide aka lye. Used in soap making, a necessary reagent in making biodiesel or use on clogged drains as examples.
1. Driveway for traction and melting . . . since it is a gravel driveway it tends to get ground in over time and since I spread it out it doesn't really track in . . . I get more mud and sand in the garage and mudroom than anything else.
2. Mix with cement and make concrete busts of Backwoods Savage splitting wood vertically.
Reactions: begreen
Driveway for traction.
I keep a 30 gallon ash can about 2/3s full for annealing and for slow cooling of welded cast iron. Use some in garden and some for landfill. Going to try oil cleanup.
I just dump it in a pile out back. Same spot I dump grass clippings, leaves, dog, moose, duck and chicken poop, etc. I guess kind of a compost pile of sorts?
I have to agree with a previous post. I use all my ashes in the lawn for moss prevention.
My grass was loaded with the stuff. I sprinkled ashes over the entire area a few weeks ago and now there are brown patches where the moss has died.
It seems the moss dies faster in the winter for whatever reason. I have treated the stuff in the summer, but it took several treatments. In the winter it seems one application does the trick.
Be sure that you aren't expecting any rain or snow for about a week. You want the ashes to sit on top of the moss for a while working it's magic.
The great thing is it greens up your yard quite a bit once spring hits.
I ued to have a moss problem on my lawn. Broadcast ash over and had a vast improvement. Lime never seemed to have the same results as ash.
I would be concerned about tracking it into the house. My wife would go bananas. But I don't actually see the traction quality. As I have said before, it works good on my lawn, especially on the moss.
Do you wear your boots past the door?
Tracking is a non-issue. Ash stays put in my experience, and it works better than sand/salt too!!
I never really knew that you could use ash for things, I always thought that it was just trash. Time to start saving it and adding it to the compost and lawn. Thanks for the info.
