jaywalker
Fire God
Yes, I do tweak the local yokels who quietly assert I am a radical and heretic who blaspheems against the Lords of the Electrical and Gas Companies; thereby being labeled unclean and untouchable. Insofar as being aware of tolerances. Understanding tolerances is how I repair exceedingly expensive toys and sometimes even get paid, though less and less in this economy. Not even many pellets or Chinese grown chickens traded in kind lately either. Must be a shortage and I'm going to die because I did not join the Oink-Oink club earlier while there were still seats on the board of directors. Sigh
Will buy a bottle of that cider when you acquire more glass containers. Why not just employ mason jars like my former door gunners from the Ozarks used. Worked for them but, what they threw back wasn't carbonated either. Burned with pretty blue flames though. Must count for something?
Seriously, however, if it is in my nature to accomplish that state of composure in the slim amount of characters provided. Every new venture in life brings on its' own set of dialogue and if you have the time and listen, you pick it up a bit at a time. The middle of Winter, however, is not the time to be timid. Ergo, until you just explained the term used for misdirected or leaking airflow, I had not a clue what to look for. The roof of enlightenment then opened and the sun of the Gods illuminated my dimmed wit. I now have a startling picture of what to look for. And, for that I thank you most heartily. I assume when you wrote about entering the fire pot, you meant that the bulk OA inlet should breath through the burning pellets from an upward angle through the lower pot vents? That being said I performed dye and high temp inlet airflow tests this afternoon. Prior to that the pot itself was etched in very mild acid then polished so the dye would flow easily. Also, I previously mentioned expanding the drilled pot holes .005.
The first firing this afternoon saw minimal die draw, even from the minute spacing along the open pot edges which were not fully welded shut. The flame was tall, aggressive and hot on setting "1" of the 5500M. An hour later after a shut-down, inspection revealed a full 1.5mm of ash dusting the pot floor. The area, inclusive of the expanded holes were not fully immune from that ash layer? Beneath the ash where the pot has been acid etched, then polished and annealed, as I would expect, There was a thin burned on layer of pellet particulates. Analysis of all available visible evidence held the preponderance of though that all of the burn holes were breathing as needed and expected yet the ash problem still remains??? This is my quandry and quest to remedy, hest I begin training for the Gnome Olympics from standing in the frost two or more times a day, scraping. OOOORRRRR? Maybe I should just pop the 6K for a Harmann. If it plays music and I can row it out on the river in the spring, it might be worth the investment? . . . NAW!
Anyways, thanks for living with the dribble!
Doug
Doug
