Something looks wrong with my little used and recently installed 30 year old (or older) Upland 17 wood stove and here is my detailed question.
The discussion about the heat baffle system and the drawing in page 3 of the manual below:
https://www.hearth.com/images/uploads/upland17manual.pdf
suggests there should be no space, and actually the drawing shows no space, between the flue opening, the firebox, and the bottom of the smoke baffle/shelf. But my stove has a space of about ½ to ¾ inch?? See the attached photo looking in from the open door.
The curved shape at the rear of the smoke baffle/shelf matches the shape at the back of the stove at the flue outlet and suggests that you do not want to have this space. It looks like the smoke baffle/shelf should be lower and further back to eliminate the space. This would force all of the smoke and hot exhaust gases to take the long path (as in the drawing) to the flue outlet. Instead, with my stove a lot of the smoke and hot exhaust gas can flow directly from the fire box and into the flue pipe and up the chimney.
But there is not any other way the current shelf could be installed to eliminate the space.
I wonder if I may have an incorrect smoke baffle/shelf part in
my stove?
![[Hearth.com] Upland 17 wood stove, new member, something looks wrong, here is my detailed question [Hearth.com] Upland 17 wood stove, new member, something looks wrong, here is my detailed question](https://www.hearth.com/talk/data/attachments/147/147022-f8d54f1d5e8b25b1511f307ccef99d7b.jpg?hash=FZXWXXVcS3)
my stove?
