When we moved into this house, they had a 1979 Frontier (I think) with an 8 inch stove pipe connected to a thimble(?) in the masonry chimney. There are 2 terracotta flues, one goes to the stove pipe and I'm not sure where the other goes, maybe to the fireplace? The damper on the dire place is rusted and I'm not sure how to open it.
Our plan was to put in a 6-inch chimney liner for our newer 2015 Magnolia stove. Unfortunately, when I went up on the roof to measure things, I found the masonry chimney is only 5 1/2 ft to the thimble and the terracotta flues are about 6 1/2 x 7 in. I believe our stove needs at least 12ft chimney for proper draft and we won't be able to fit an insulated 6-in chimney liner inside the terracotta flue (and the current flues are all cracked up so we can't use them as is) and so now I'm not sure how to make our chimney work for our stove.
We are pretty competent DIYers but fairly inexperienced with masonry. We planned on repointing the brick in the spring, as it shows some wear on the one side where water runs down from the roof peak. I'm a little afraid of the prospect of removing the terracotta flues, which I'm imagining is going to be the answer we get on the proper way to proceed (my husband is not a fan of that at all). We don't have thousands of dollars to throw at a chimney rebuild, I had budgeted about a thousand dollars for the chimney liner and stovepipe before I realized that probably wouldn't work so I'm hoping that we can figure out a fix that isn't too much more than that, assuming it's something we can do ourselves or with limited hired help.
Hoping the photos load correctly, the thimble is mostly hidden behind a picture at the moment, the flue with all the cracks is the one that goes to the thimble. Any additional info needed, please ask!
![Upgrading stove and unsure how to upgrade chimney Upgrading stove and unsure how to upgrade chimney](https://www.hearth.com/talk/data/attachments/306/306718-80d829038829d45dcb105b85c187ce20.jpg)
![Upgrading stove and unsure how to upgrade chimney Upgrading stove and unsure how to upgrade chimney](https://www.hearth.com/talk/data/attachments/306/306715-0624c40f811bdb00bb23b3acf5f3746c.jpg)
![Upgrading stove and unsure how to upgrade chimney Upgrading stove and unsure how to upgrade chimney](https://www.hearth.com/talk/data/attachments/306/306716-efa39db53c9f38fdfb397f860425dc90.jpg)
![Upgrading stove and unsure how to upgrade chimney Upgrading stove and unsure how to upgrade chimney](https://www.hearth.com/talk/data/attachments/306/306717-37f75a8b0e829129e30f923c9e15ccd0.jpg)
