With a catalytic stove you can smoulder the wood and the cats stay engaged with enough smoke going through them,  the nice thing with the BK stoves is the Bi-metallic thermostat that regulates the air to keep the cat in the active zone and producing heat.  Pretty much a set and forget stove.
I would recommend getting double wall as with a stove like this that idles so low you want to keep the temps in the chimney higher so you don't loose draft.
 I believe. Wife and I argue about the princess. Even with the legs instead of pedestal I don't think she'll swing for it. I'm also a little apprehensive bc I think the princess even on its lowest setting will be too much for our house and in the winter id prefer to keep a steady fire going.
