We are considering upgrading our existing Avalon Rainier fireplace insert. I actually purchased this stove for another home but we purchased our existing home before it was installed. We had tons of projects to complete on the new home and our budget didn't allow another stove purchase so we installed this one. It works pretty well but the two things I don't like are the small firebox which doesn't allow for standard length splits (16") to be loaded N-S; also the stove burn times are shorter than I would like. We burn mostly douglas fir, hemlock and some alder.
The Avalon has a fan which if we run it does push some heat to the far end of the house but makes the living room warmer than I would like.
We don't have any HVAC ducting in the house. Part of what I need help with is figuring out if there's a way to get the heat from the insert to the far end of the house and more even overall heat distribution. We do have a ductless heat pump system install that does a decent job heating the house but the wood heat feels better and I prefer it in our damp NW climate.
So, what would you recommend for a new insert that can burn low and slow? Blaze King seems to be the answer, but will a princess cook us out of the living room? I think an insert that can put out decent heat for 6-8 hours and the fan on low would do a decent job, but also looking for ideas to help get the heat to the far end of the house. The far end of the house is about 24" lower than the main part and on a slab so ducting would have to run in the attic.
![Upgrade Insert, Blaze King or ? Small Chopped Up Home. Upgrade Insert, Blaze King or ? Small Chopped Up Home.](https://www.hearth.com/talk/data/attachments/201/201678-e4e464f276257fefe70ad9da2107b8d7.jpg)
