Keneth Ryno
- Mar 26, 2012
- 1
Jabo's friend here. Jabo came up and we installed a Dayton Auger motor AC Gearmotor, Parallel Shaft, Voltage Rating 115, 1 Phase, 60/50 Hz, Nameplate RPM 4, Full Load Torque (In.-Lbs.) 175, Overhung Load (Lb.) 55, Input HP 1/60, Gear Ratio 796:1, Full Load Amps 1.2, Insulation Class B, Open Enclosure, Auto Thermal Protection, All Position Mounting, Motor Type Shaded Pole. The only difference with this motor then the Avery Gleason that was in my Accentra wood pellet stove was the fact that the shaft was turning clockwise and we needed it to turn counter clockwise. So after further review we reversed the winding of the motor so the power posts were towards the gear box and this made the shaft turn counter clockwise. Brilliant right, so it is working fine and all is well in Pellet stove land again. Once again the Motor is a Dayton 5CFL1 Shaded Pole Gearmotor and can be purchased at Grainger. Thanks for all of your input and hope this little ditty might be of help to others when it comes to replacing the auger motor.
