Medic21
You will have a totally different system than mine. The hydronic floor and radiators are closed systems and you will need to set up plate exchangers, mixing valves(most are 110-130 degree systems), manifold systems.I don't currently have an OWB. I am using a add on wood furnace rated for 200 BTUs. It shares the existing duct work for the hot air oil fired furnace that has not fired in over a decade. I plan to convert to hydronic heat, with radiant floor on the first level, and cast rads on the second level. I will run feed lines to the attic and feed the second floor with legs from each rad. This house has been 65-70% remodeled on the interior, making it much easier to feed rads from the attic.
At this point I'm planing ahead of my schedule. Concrete pad, underground lines, then shed by June / July. I will be adding the boiler in the fall. The boiler shed will sit right where I process my firewood. It takes far to much of my time to process the wood, season it, then move it to the opposite side of the house where the bilco doors are to feed the indoor wood furnace. Not to mention this hot air duct system dates to the 50s and sucks. Total run from OWB to house is just under 150'. That is with a little length to spare, so I think my measurements were 141' including a couple feet into foundation and into shed.
I hope I'm painting a clear picture here.
After reading through the sticky thread, I have decided on the manufactured foam lines. I'll eat the cost up front once. 1-1/4" is my best bet.
I want to go there eventually but the cost is around $16k to add that to my house. Much more even heat and more efficient in the end.
It would behoove you to have a professional HVAC person to design and tell you what to build. I will stick with my forced air until the remodeling happens in a few years.
