earthharvester said:We over sized, our house is 1400' our Quad 4300 is rated at 1800-2200 square feet. it is doing a great job at heating it.
Cleanest burning large stove of it's kind, if I remember correctly.
tradergordo said:castiron said:Do you happen to have some amazing efficient air conditioner by any chance? Because that will probably be my next project (for next summer). My electric is REALLY expensive (>15 cents per kWh - 57% above the 2006 national average, despite living right near a coal power plant in the most coal rich state in the country, and almost within sight of a huge nuclear power plant).
I preached all last summer about ditching the central A/C and going with Energy Star window units. My problem has usually been with getting enough dehumidification. 3 years ago, I bought a small 9k BTU Energy Star window unit and stuck it a 1300 sq/ft rancher. To my surprise it met about 90 percent of my cooling needs and kept the indoor humidity level well below 60%. To my better surprise it cut the A/C bill nearly in half. I set mine at 73 degrees and let it run.
I believe most A/C systems are oversized.
You can buy these small window units for like $150. Just make sure its energy star. You can fabricate a simple, more airtight mounting system with plywood.
Btw, I moved into a different house this year (shacking up with the women), installed my trusty little window shaker. Her summertime electric bills last year were well over 200, and I think the biggest one was 100, for August.
BrotherBart has come to the same conclusion, and lets see if he chimes in here.
Sandor said:I preached all last summer about ditching the central A/C and going with Energy Star window units. My problem has usually been with getting enough dehumidification. 3 years ago, I bought a small 9k BTU Energy Star window unit and stuck it a 1300 sq/ft rancher. To my surprise it met about 90 percent of my cooling needs and kept the indoor humidity level well below 60%. To my better surprise it cut the A/C bill nearly in half. I set mine at 73 degrees and let it run.
tradergordo said:Sandor said:I preached all last summer about ditching the central A/C and going with Energy Star window units. My problem has usually been with getting enough dehumidification. 3 years ago, I bought a small 9k BTU Energy Star window unit and stuck it a 1300 sq/ft rancher. To my surprise it met about 90 percent of my cooling needs and kept the indoor humidity level well below 60%. To my better surprise it cut the A/C bill nearly in half. I set mine at 73 degrees and let it run.
I think that's good advice. I will be on the lookup for window unit AC. This summer when I was scrounging wood off a new home construction site I noticed a brand new built home (was a large two story home, I'm sure quite expensive) with a window AC unit for the master bedroom. It surprised me to see this, and my friend said "that's actually a really good idea). So maybe this is becoming a trend. As was mentioned in that hearth & home mag article - space heating (AND COOLING) is pretty much always more efficient. I guess the major drawbacks to window unit AC is the noise and the appearance factor.
p.s. castiron - I replaced all my light bulbs with compact fluorescents YEARS ago. I also have a high efficiency washer/dryer. One of the big problems I think (besides inefficient HVAC) are vampire appliances (everything from TVs, set top boxes, telephones, computers & routers, various cradles and chargers, etc.) that stuck down electricity even when not in use. I want to get a kill-a-watt meter to see how many vampires I have and how much energy they are wasting.
p.p.s. I'm not convinced yet those "on demand" tankless water heaters are a good idea. I read a great article I will try to find - but basically it said that the massive energy used for on demand hot water ends up being just as much as leaving the pilot going on a well insulated traditional tank water heater. In the real world customers were finding that not only did they often not get enough hot water, but they also didn't conserve any energy. There were comments left to the article from actual customers (most of whom were not happy with their overpriced, overhyped, underperforming tankless water heaters).
UPDATE: Here's the article!
Tankless Water Heaters - Some Surprising Facts
Rhonemas said:I think it's been hi-jacked. I have a tankless that uses oil.
