- Feb 10, 2006
- 259
JPapiPE said:I did buy the Super Cedars 100 Super-pak for $64 including delivery to my door. Do you think I paid too much? The way I understand these fire starters...Is that they provide a consistant flame for a long enought period to catch fire to kindling, small splits and slightly larger splits. Where is the benefit? Does one use less kindling, less newpaper or fewer matches? And how are these fire starters used In Bart's Burn Method from the top method of starting a wood fire?
Thank you all
When I use Fire Brinks to start a fire there is only one method, my own. Take the fire bricks posted earlier. I use the one on the right. Some may use two or more, but I only require one brick. I don't use newspaper too often unless they begin to pile up. My kindles compose of branches not very small splits the size of shims, so I need a good fire at startup.
