Two great products I just discovered - ultimate "cart" + poison ivy immunity!
tradergordo
820
Phoenixville, PA
gordosoft.com
I'm not being compensated for these reviews, but I recently discovered two products that are so great I felt compelled to mention them here.
Rubbermaid Big Wheel Cart
Link is for info only and others' reviews, if you were to buy it, I'd go to Home Depot where you can check it out yourself, price is currently $155 (maybe they clearance these soon??). There are some things that should be bought in person and this is one.
Yes, its expensive for a cart, but this is the ultimate cart as far as I'm concerned. I previously owned the "gorilla" cart (Tractor Supply sells it, also on Amazon) and I liked it at first, but its really not great - it easily tips over when loaded, and its thin metal parts rusted out and broke over time. I knew I had to replace it, and in the back of my mind I knew I wanted something plastic that would not rust. This rubermaid cart is made from a composite type high density poly ethelyne, it seems indestructible (its thick).
Here's the part that is almost hard to describe, you just have to try it yourself - this thing has freakishly perfect balance and ergonomics - you can tell the Rubermaid engineers really put some work into this design. Load it up overflowing with heavy splits of wood or dirt and you will be surprised the first time you use it, it moves almost effortlessly - it's magnitudes better than any wheel barrow I have ever used, and much better than the gorilla cart. This thing can dump if you want, but because of the low center of gravity and wide wheel base, it is never going to accidentally tip over on you like other carts do.
There was one significant complaint I read about in reviews of this cart, which was related to tires going flat - I was ecstatic to discover that Rubbermaid actually listens and improves their products - they changed the tires over (starting August 2011) to SOLID (foam core I beleive) design instead of tubes - you do NOT put air in them at all. These tires are fantastic and look like they will last forever, they are huge (maybe 2 feet?) and narrow making it perfect for effortlessly rolling across any terrain. I really believe this is a high quality product that is going to last me a very long time (more than 10 years, possibly much more). If you decide to buy one, definitely check out the tires first - some stores are STILL SELLING the old version with tube tires (you can easily tell the difference, there is no valve stem on the new ones). Don't buy the version with tube tires.
The second product that I can't say enough good things about is:
Oral Ivy
Read the reviews on Amazon, they speak for themselves. This product really works. I get poison ivy every year (by the way, I use the term poison ivy, but poison oak/ivy/sumac - both vines and ground versions all have the same exact compound in them so they are all covered). This year I got it real bad and decided to look for anything that might help. I got this product, which believe it or not, IS poison ivy in liquid form (very dilluted) that you actually drink (only a few drops) daily. This builds your body's immunity up. I only bought it because of the great reviews, and it is pretty cheap. I'm the kind of guy that isn't satisfied until a product is put to the test. Yes, I intentially exposed myself to poison ivy 3 times after taking the product for almost a month (I wanted to be sure it was in my system) and yes, it works beautifully! Now I'm not going to say I had no reaction whatsoever, that is not how it works. The way it works is your reaction is minimized to such a degree that your poison ivy "outbreak" doesn't even bother you. You will still see a mild "rash" but it does not itch at all, and it crusts over in 24 hours and quickly goes away. I've been exposed to poison ivy 3 times now since I started taking Oral Ivy and I've seen the same thing all three times.
I think you can take less than the amount recommended and still have the benefit. I take just 3 drops a day, only M-F. I think you could take 3-4 drops every other day and it would still work. This will make one bottle last a full year.
It would be interesting to see if you could make this product yourself, say by blending up a few poison ivy leaves in 70% alcohol solution and then filtering it (coffee filter) - perhaps you could, but I have no idea what the correct strength should be, you definitely don't want to overdo it.
-Gordo
Please note that "rubbing alcohol" and "alcohol" does not mean the same thing. Rubbing alcohol should NOT be ingested in any amount.
Nice review Gordo. I love it when products live up to their claims.
I had a "crazy " uncle that used to EAT Poison ivy leaves :gulp: !!!! I never did but he swore it kept him from getting any rash. I am NOT recommending anyone eat Poison ivy leaves. I am not a Dr and never played one on TV!
That's actually the original homeopathic treatment I've heard of, supposedly passed down to us by natives. I'm sure glad I'm naturally immune to the stuff, but please... somebody let me know how it tastes, will ya? I might wanna use some in salads. %-P
When my father and his brothers were young, they spent their summers at their Aunt Maude's, a one room cabin near Nipinnawasee (sp?) near Yosemite in the poison oak belt of California. She fed them poison oak leaves broken up in their oatmeal, starting with very small amounts and gradually increasing. They all became immune, my father's immunity lasted his entire life.
I seem to find the poisonous type of woman, so I'm thinking maybe I can just eat them - small doses at a time, of course - to develop an immunity?? Who knew Homeopathy could be so deliscious?!! %-P
Oooh! Oooh! Jeffery Dahmer was just trying to cure his homophobia with homeopathy!
Good luck with that cart I have a pile of broken plastic garden carts.. The plastic gets brittle when cold and one dropped log is the end of the story.. The 3rd and last cart I destroyed was a Scotts cart and my wife was not happy I broke her cart lol
Ray
Ray
Don't lump all plastics together, there is the cheap stuff and the good stuff. PVC for example gets brittle at 32 degrees, but HDPE ( the stuff this cart is made from) gets brittle at -180 degrees! I suspect it is about as indestructible as a plastic kayak. From what I've read HDPE pipes are more reliable than any other material, even holding up when water repeatedly freezes and thaws inside them.
Usually "homeopathic" indicates such massive dilution that no molecule of the solute remains, and thus the claims of efficacy depend on pseudoscience (the "memory" of the solute molecules in the solvent). But following various links on the Oral Ivy, it appears to actually contain measurable amounts of poison-ivy extract, and thus isn't really homeopathic in the usual sense but rather is hiding behind the blanket safety exemption given to "homeopathic" remedies. Zicam did the same thing with zinc nasal swabs a few years ago, which were ultimately recalled because they caused permanent loss of smell. I'm not saying Oral Ivy or similar things aren't safe, just that anything labeled as "homeopathic" has not been required to undergo any safety tests. (Same for "nutritional supplements".)
+1
Those Rubbermaid carts are totally different than the common poly carts that everyone sells. I have the 10 cu.ft. Rubbermaid cart to tow behind a lawn/garden tractor, and it is by far THE BEST cart I've ever used. We've used and abused that thing with logs, stone, gravel, leaves, grass, dirt, sand, and bricks and it hasn't suffered even a little chip. IMO, it's even better than a steel cart of the same size because it doesn't dent or rust and is MUCH LIGHTER. The only negative is price.
Rubbermaid Lawn Tractor Cart Trailer 10 Cu. Ft.
I had a cart like that about ten years ago. It was a Craftsman. Dang thing couldn't handle two bundles of shingles and the wheels kept breaking off. Perhaps the Rubbermaid version is stronger.
my grandmother said her 1st husband told her to eat the new leaves on poison ivy and she never got it afterwards. i know if i tried i would probably be inflammed for weeks, miss work, and get it easier than before. just how my luck goes.
tradergordo said:
Don't lump all plastics together, there is the cheap stuff and the good stuff...
Ja, they make plastic snow shovels and I've got some that are more than 15 years old. Got a poly cart too for pulling behind the tractor too, but to be honest, I've never used it in brutally cold weather.
I've been thinking of geting a Rubbermaid cart like that for the wife... maybe 3 or 4 of them. Somehow she manages to tie up both wheelbarrows, my poly cart, and her 4 wheel wagon.
I did look into Oral Ivy quite a bit before taking it. It turns out that it has been around for a very long time (at least 60 years) and has been studied quite a bit and written about in medical journals, if you check this letter from a doc, at the bottom are references to various source info:
http://www.oralivy.com/hoagland.html
I saw that as well, and agree that the documentation puts it in a somewhat better category than your run-of-the-mill quackery. However, note that the statement indicates that the product can actually aggravate existing symptoms, and yet the marketing and directions indicate use for both prevention and treatment.
My main point was that this product does have an active ingredient, and yet has chosen to avoid any regulation on its purity, efficacy, and safety. I'm sure the decision to (incorrectly) label the product as "homeopathic" was simply a business decision, as getting FDA approval for real treatments (as opposed to fake ones like homeopathy) can be expensive. But by cynically and dishonestly invoking this gaping loophole they put themselves in very bad company.
I personally don't think they should market it as a treatment based on what I've read (many people got even worse when using it to treat an existing outbreak). As for calling it "homeopathic" - I don't really understand what you mean. Wicktionary has only one definition:
(medicine) a system of treating diseases with small amounts of substances which, in larger amounts, would produce the observed symptoms.
Oral Ivy sure seems to fit into this definition.
One thing I discovered in reading about the studies that have been done is that in one major study they recommended taking it just 3 days a week (basically every other day) as a maintenance dose after initially taking it every day for a month. This isn't on the instructions that come with the product.
I think
http://en.wikipedia.org/wiki/Homeopathy
and
http://nccam.nih.gov/health/homeopathy/
give a fuller description. (Note that the NIH link is from a center within NIH specifically set up to be "fair" to alternative therapies.) In a broad sense anything dissolved in a liquid could qualify as homeopathic; the reason homeopathic remedies are generally regarded as safe, however, is that they are usually diluted beyond Avogadro's limit. The second link states:
The principle of dilutions (or "law of minimum dose") states that the lower the dose of the medication, the greater its effectiveness. In homeopathy, substances are diluted in a stepwise fashion and shaken vigorously between each dilution. This process, referred to as "potentization," is believed to transmit some form of information or energy from the original substance to the final diluted remedy. Most homeopathic remedies are so dilute that no molecules of the healing substance remain; however, in homeopathy, it is believed that the substance has left its imprint or "essence," which stimulates the body to heal itself (this theory is called the "memory of water").
I don't that's what Oral Ivy is claiming to be, although I didn't find a concentration level listed. I understand it to contain a measurable amount of poison ivy extract, which over time desensitizes a person to the compound. That's not what homeopathy claims to be. But it seems to be true that by US law a solution can be labeled homeopathic and sold OTC as long as it claims to treat a minor condition and contains substances listed in the "Homœopathic Pharmacopœia".
I have the Rubbermaid big wheel cart and I have also found it to be extremely durable and well balanced.
Ray
This is really a heavy duty material. Not molded plastic. More rubberized. Not brittle at all and will not break when frozen. We've had this exact cart for years. My bride uses it as her garden cart when she's raking leaves, etc. She also dumps the grass catcher into it when she's mowing the lawn. The big bicycle type wheels make it easy for her to haul everything to her dump spot way back in the woods.
Our only issue is that all the sticker burrs we have wreak havoc on tires so I have 'Slime' in them and that helps somewhat.
It's a great cart.
DiscoInferno said:
I think
and
Well I definitely learned something, didn't know what "homepathic" even meant until you got me curious. For what its worth I see what you meant now. To me, that silliness about water memory and energy imprints is all complete quackery nonsense. I agree that this product does not fit into this category. Its Rhus 3x, which means you take one of the most potent skin toxins in the world and dilute it 3000 times (so imagine .1 ml of poison to 300 ml alcohol. At this concentration the rhus should remain active to some extent I would imagine (but I'm no expert). All I know is that it seemed to work well for me and many others. I may deliberately put it to the test again next spring with fresh poison ivy leaves just to be sure.
LLigetfa said:
Got a poly cart too for pulling behind the tractor too, but to be honest, I've never used it in brutally cold weather...
Not brutally cold but I used my poly cart today in -10°C to move 2 cord to the shed. Got another 2 cord to move tomorrow. Sure could use tire chains.
I have that cart and really like it but it is not indestructible. I broke the lip dumping gravel. I'm thinking I will reinforce it with steel kind of like a cutter bar on a loader bucket.
  • Two great products I just discovered - ultimate "cart" + poison ivy immunity!
Yup I have managed to break every plastic cart I have ever owned.. My steel mesh wagon has lasted much better and I use it often with heavy large loads and keep it stored inside the wood shelter..
Ray
