maple1
Pics might help here too. Multiple 5" take-offs off an 8" trunk won't hurt things. But one 8" trunk going to one 5" vent is another thing. Might be stuff getting lost in translations here....
Yep I reduce to 5 inch
So if I understand this right, you have two 8" "trunk" lines running the length of the house, and then 5" runs off of that going to the registers?
I'm using side to side. About the ductwork my main run is 8 " then I have it branch off from that to my roomsAre you using the side-by-side outlets on the top of the furnace, or the front and back outlets?
If that's the case then dampers should be on the 5" runs or have closable register vent coversI'm using side to side. About the ductwork my main run is 8 " then I have it branch off from that to my rooms
I have closable ones in my vents,SBI said to put one each in the 8" but it makes more sense what your saying I will do thatIf that's the case then dampers should be on the 5" runs or have closable register vent covers
how long will your blower stay on if the damper is closedI started running my Tundra in mid November and am very happy with it.
My blower does not stay on constantly, it cycles but keeps the house warm enough to keep the propane off.
what is the manufur date on yours did u have the chage the thermodisc on yours.I have never timed it. It just cycles on and off and varies a lot depending on what part of the burn cycle it is.
no i did not know about it only for the guy on here, im going to call sbi tomorrow. mind was manf 28/02/2013 only install it 3-4 months ago. call sbiI think mine is the older version I brought it in Feb 2014
does your furnace have the thermodisc on top or the back.I think mine is the older version I brought it in Feb 2014
they have a kit the guys said that comes with the cold air intake, with a different temp cut in cut out then the one u have i say and it mounts to tope of your furnace.back
that is funny . the guys sent me a picture with the update with the things to put the therodisc on top. so did u order your ket from sbiI have the cold air kit but it didn't involve moving the disc
im not realy sure but i say one on here can anwer that for ya.I wonder if you can get a Tundra with a door handle on the left side? You know for right handers. That and the cheesy ash pan door setup are the worst in my mind.
I ordered the kit with the furnace back in Feb 2014 , the disc on the top is a newer thing
iI ordered the kit with the furnace back in Feb 2014 , the disc on the top is a newer thing
hi do u have your furnace install yet. i dont now how i can get the picture the guys sent to me to send to u .I wonder if you can get a Tundra with a door handle on the left side? You know for right handers. That and the cheesy ash pan door setup are the worst in my mind.
No. They said it would cost too much to make it a left/right door. Trying to make a pricepoint for retail stores and all...I wonder if you can get a Tundra with a door handle on the left side?
You can get a PSG Caddy, same furnace only more HD and have to get from a dealer, 'bout twice as much $$ too.That and the cheesy ash pan door setup are the worst in my mind.
https://www.hearth.com/talk/attachments/image-9-jpg.152938/hi do u have your furnace install yet. i dont now how i can get the picture the guys sent to me to send to u .
u see pictures that brenndatomu sentI ordered the kit with the furnace back in Feb 2014 , the disc on the top is a newer thing
Did u get a new thermodisc with the kit
