Hello again all,
Biomass 40 is running top notch now, thanks to tips and tricks of everyone here. It's cycling nice, clean, and I coulnd't be happier.
My next problem is a whole other can of worms (and has lead me down the rabbit hole already trying to diagnose).
My Heating/Cooling guy and I are trying to figure out why I've got low output temps on my tube shell exchanger. Pic follows with current readings after about 48 hours of continuous burn. Bottom line is, I can't crack around 150F. I have 3 water heaters used as storage/buffer, so only about 150 gallons. I have a 16x20 air/water HX in the furnace and a solitary 5 foot slat-fin rad in the upstairs bedroom. 3 speed pumps for each (storage, furnace, rad). Have experimented with all speeds, found that has little impact.
Now all this to say, at around 10F outside, I can keep the 1800 sqft farm house at around 68F, but based on the output numbers, I know there's something amiss. There's got to be more heat there.
Last piece of the puzzle is the tube shell - it's 85,000 but/h. Is it possibly undersized?
Needless to say, I'm happy that the 80,000 btu propane furnace has been silent for over 30 days.View attachment 156187
A few things don't seem right. Like already mentioned, the boiler connections should be reversed. Secondly, the domestic water connections should also be reversed. I think this will make the difference. Enclosed is a suggestion for the changes. Good luck.
At 3 GPM you should be able to make it work with a little wiggle room if you find a much larger HX. The load isn't that high but you need a close approach HX to meet your heat emitter requirements. Pay attention to the head loss in the new HX if you go that route.
They generally have high head at rated output especially the flat plate type. If you go much larger the head loss will be much less at the lower flow rate and the delta T will be much tighter.
I'm thinking something along these lines and your existing pump may work:
I would definitely calculate your HX before you buy one as they are not inexpensive!
Hello again all,
