Tonyray for all the hassle and cost's just have your pellet's delivered, you'll waste $100's on a cheap trailer , It's not worth It
			This is why I like my split gate trailer. When I need to get my garden tractor on I use the whole ramp, pellets I leave it folded in two and drop it to the ground with the half length ramp.A trailer without operating gate would be a waste to me. Someday you may want to pick up or move a washer / dryer, fridge, kitchen range........ How would you load these items? Also getting a load of mulch, stone, top soil....... you want to be able to shovel it off the back easily. I'd be lost without one that tilts as well. Lawn tractors, stoves......... my Snow Bear (Canadian) tail gate removes and lays down flat just like the front making it a 14 foot long flat bed.
You want 10% of load weight on tongue to prevent fishtailing on a small trailer. More than that squats lightweight vehicles, (and is usually the hitch weight max. or vertical weight on hitch) less than that, the trailer won't follow straight and true behind you. Some are limited by tire capacity. The larger tire diameter the better due to bearing temperature and wheel speed.
Retired a couple years ago from my own RV business including Reese distributor / installer of weight distributing hitches since 1989.
Time for me to put my Penney's worth in this discussion, Don't buy a trailer rent one from U Haul and try it out
Good idea there. I just checked on the pricing and the smallest that can haul a full ton is about $30 a day. That's only $3 more than the registration on my popup camper trailer costs.
Time for me to put my Penney's worth in this discussion, Don't buy a trailer rent one from U Haul and try it out the first time you haul something then you will know more about trailers and what you really need and want.
I realize that it is money down the drain but it is very little and an education always costs something.
Anyway good luck with the project, Don't let the nay Sayers put down the Toyota they are voicing an opinion with never having the enjoyment of owning one.
I need to put 5 tons in my basement this spring/summer..[acually 4 since have a ton down there]
after I have the hitch/light kit installed, I will check out U-Hauls trailer rent pricing.
either way I go, I do need at least the Hitch/lights.
Knowing lot more now about pellet quality, who knows if this spring or next I might get 4-5 tons from 4 or so different places..HD included ...
don't want to pay the going rate in my area of 65.00 4 or 5 times...
[ my stove dealer, who's prices have jumped alot this year] has his wharehouse close enough to my house that he could almost throw them to me.[ exgaerating but 1/4 mile or so].
still wants 65.00 to deliver minimum 1 ton..that's one reason I want to shop around as prob will not buy from him anymore.only carries 2 type Energex hardwoods,.same with HD which 1/4 mile opposite direction.
besides, I like the hunt and like to try few different pellet brands each year.
4 Subaru's and 1 Toyota truck in past 35 yrs.. traded all 4 Sube's in excellent running condition.I will NEVER put down Toyota. My last 4 cars are / were a Toyota. Tercel, Celica, Rav4, Tundra (my currrent vehicle)
this '92 Pickup has low 80's in ORIGINAL miles..I've never had a Toyota die on me. All were traded in excellet working condition.
good Idea about " take it for a spin 1st at U Haul.." as long as I have to hitch/lights installed, that's makes sense..Time for me to put my Penney's worth in this discussion, Don't buy a trailer rent one from U Haul and try it out the first time you haul something then you will know more about trailers and what you really need and want.
very good read.. thanks.Actually the weight should be slightly forward of the axle pivot point. You want about 100- 250 lb of tongue weight on the hitch. This affords proper tracking of the trailer. Centering the weight over the axle is generally a little shy on tongue weight .. When inspecting a trailer design you will see that the axle is rearward of center to the bed of most trailers. They are built that way for a purpose. I've built several trailers and spoke with other trailer builders.about balance as well. The first serious trailer I built was a car hauler with dual axles. You will notice as you move the weight a bit towards the tow vehicle how much more you don't even notice the trailer is behind you other than pulling hills and braking. Tracking becomes more one with the tow vehicle, less sway, less bobbing, assuming everything is in good condition and properly inflated tires.
Tony, I've found tie downs and broken down pellet pallets ( so called half or partial pallets) to be totally useless. The pellets just slide out from under the tie downs. However a whole pallet as it comes purchased from the store I would haul to California and back and it would stay together.. So if you are going to break them down anyway, just go all the way and spread them out between tow vehicle and the trailer bed to meet your GVW. Unless you have a means of re wrapping a 1/2 or 2/3 pallet of pellets ( they do make rolls of pallet wrap, the beverage industry for one industry uses that to hand wrap hand stacked pallets of soda for transport on the bulk soda trucks, which have the same issue over the road of spilling soda cases all over the bed of the truck.. The side loader trailers don't need that as the pallets are better contained on those. I was a fleet mech for 44 years in the beverage industry, fwiw, I've worked on many many trailers of all trypes and description.. Excuse me for trying to instill some credibility into my message LOL !! If you are going to split the load anyway, then the 2000lb payload capacity is irrelevant .But it's very relevant if you want them to slide a ton on and drive away..It's always nice to have a trailer that is a little too beefy for your purpose, then you don't have to think about it. Always think safety, know that thing can blow apart if too light, know that there are others on the road with you, so secure your load by the best means. Now 40 lb bags of pellets aren't blowing out of the bed of your trailer but they can fall there, not a nice scene. Not a nice mess to pick up and not nice as an obstacle course to other drivers either. It's a matter of using common sense.
I have a few things to recommend.
I doubt there is a 4x6 trailer anywhere in the US hauling over the road that has trailer brakes or even the attaching flanges to mount brakes on to. Not in the class of trailer he is looking at anyway.I would suggest trailer brakes if you plan on towing anywhere near the capacity of your vehicle.
not in may area...In April I ordered my pellets and coal for a late summer fall delivery. The dealer had a 1/2 price on delivery going on for an early buy, which for me was $35 to deliver 3 tons of pellets and 1.2 tons of coal (4 pallets total) placed behind my barn. The $35 is more than worth it to me to not have to go somewhere and load pellets to a trailer or truck and then unload them at home. I don't know if other dealers offer delivery like this, but I would certainly look for a dealer that did.
