Maybe a dumb question - but has anyone experimented with using an automotive O2 sensor in a gasifier stack to see what the combustion exhaust looks like?  Would this work as a way to function as a control variable that would account for the varying amounts of combustibles in the wood - say by modulating the fans and / or possibly a stack damper to maintain an "optimum" level of O2 in the exhaust stream?
Another possible place where it might be possible to modulate, though it would probably be difficult to find an appropriate material and control system, would be the size of the gas orifice between the wood chamber and the 2ndary chamber - If it were feasible to adjust that on the fly - possibly by sliding some sort of plate into the opening - then reducing the volume of gas going into the secondary chamber should reduce the heat output, which should eventually reduce the heat back to the wood chamber and slow down the gas output, nice negative feedback loop? Might want to have some sort of interlock on the door to the wood chamber though, as it wouldn't be good to open the door on a chamber full of backed up wood gas - a potentially explosive combo...
Gooserider
Gooserider
