2 years ago we bought a new house, built in the late 70's, and the first thing we did was weatherize. This was a combination of air sealing the box sills and the chimney chase as well as other protrusions in the second floor ceiling. Not surprisingly this made out house much tighter and more efficient to heat. However, an unintended consequence was that infiltration, presumably due to the chimney effect in extreme cold temps (think -20F, Vermont), took place in our Jotul Fireplace insert when it was not in use. The breeze coming from the insert is very noticeable and makes the living room in the house VERY cold. 5-8 degrees colder despite essentially being and open concept layout with the rest of the first floor (Though the living room is slab on grade about 12 inches lower then the main part of the house.) Additionally the chimney is exterior. To give an idea of the negative pressure we experience, if I want to start up the insert from cold, I have to open an exterior door, prime the flue with a torch and then light a big newspaper fireball to establish the updraft.
Here is an annotated photo of our house (with arrow pointing to the exterior chimney:
![Trying to mitigate chimney effect...HELP! Trying to mitigate chimney effect...HELP!](https://www.hearth.com/talk/data/attachments/294/294498-41e5ce53188afcd09f6a8517b26c4936.jpg)
And here is the woodstove/fireplace:
![Trying to mitigate chimney effect...HELP! Trying to mitigate chimney effect...HELP!](https://www.hearth.com/talk/data/attachments/294/294499-8033cce40e0bfc1d1dbe307d55fa1287.jpg)
As for how to combat this backflow when the stove is not in use, I can think of two solutions: An Outside Air Kit (OAK) for the insert, or a top mounted flue damper. Each has it's pros and cons AFAIK:
If you are still reading, thanks
! There is no clear fix that I can think of, but i also have to imagine i am not the only one facing this issue. That's why i am am posting. If anyone has suggestions, please share
I love burning wood on the coldest days. we otherwise heat with air source minisplits which are super nice until it gets down to ~-10F and have resistance heat if needed.
Thanks in advance![shock !!! !!!](/talk/styles/default/xenforo/smileys/shock.gif)
Solution | Pros | Cons |
Outside Air Adapter |
Top Mounted Damper |
Thanks in advance
