Hello,
To begin, I have been in touch with Englander’s tech/service team via email and thus far they seem stumped. The short version is: our Englander is throwing lukewarm air in spite of implementing fixes (several of which I found here in this forum).
Longer version:
My bf and I purchased a used Englander 25-PDVC from a friend two weeks ago. To our knowledge, any maintenance he did in his 8-odd years of owning it was fairly minimal, limited to just vacuuming. He told us that the last time he used it, roughly 2 years ago go, it worked fine. The first day we installed it, the very dirty stove ran splendidly, and we were sweltering. Awesome, right?
Pleased, BF and I decided to go ahead and clean it up. And that’s when trouble seemed to start. We noticed what we later would learn was called a lazy fire (heavy soot, thick, cakey ash) and a very lackluster heat output. The lazy fire issue seems to have been resolved as of this weekend after replacing door gaskets, however.
Here’s the list of what we did over the following days:
* Vacuumed and cleaned the ash out of the fire box, vacuumed the fire pot, etc
* Vacuumed the heat exchange space behind the impingement plate
* Cresote removal - scraped layers of that off the impingement plate and the fire box walls
* Air intake - confirmed that air is indeed being sucked in from the outside
* Combustion blower replacement - upgraded with the current version (brainfarting on the name).
* Convection fan - cleaned (this had several layers of pet hair and dirt) and reinstalled.
* Fire pot gasket - replaced
* Fire pot burn plate - plugged up holes, replacement will be ordered
* Door glass gasket - replaced
* Door gasket - replaced
* Control panel - factory reset and also confirmed that all the wires are seated correctly
* Augurs - the timing seems to be correct. We have NOT pulled this out yet to inspect, however, because most past threads on this topic did not suggest this avenue.
Replacing the gaskets seem to have improved the lazy fire, but we are still getting lackluster heat compared with that first day.
Thoughts??
Longer version:
Thoughts??
