PM answered. 1 other thing, when you had the auger motor out, while it was turning was it turning the correct way? And did you try and apply pressure to the output shaft and see if it would or could be stopped easy?
Auger was turning the correct way. I did not apply pressure to the output shaft and see if it would or could be stopped, something that never entered my mind.
Note: When I reinstalled auger motor then started stove, I couldn't see it turning at the bottom of the pellet bin.
I purposely left pellets out of the bin, so I could actually see the auger turn, it didn't.
I then filled bin to cover the auger, figuring without pellets it may cause a vacuum condition, but pellets still failed to drop.
Continuing my research to solve..........
