M
MasterMech
Guest
I think Briggs trademarked that one.I have also seen where valves heat and start to stick, but admittedly not on the K series Kohlers.
I think Briggs trademarked that one.![]()
Huh - thats odd. Most briggs are usually so sloppy I couldn't imagine anything sticking.
(Full disclosure - I run an 8hp briggs on my splitter and it performs flawlessly).
Coil. I have also seen where when cold, the coil will work just fine, but as they heat up, an internal "open" will happen. I have personally had this happen twice over the years.
Think you can still buy those coils at NAPA.Seriously.
was it warped?Head drop off at the machine shop.
was it warped?
i would get the old ohm meter out and test the stator, coil, etc... hot and cold
dont remember if the resistance specs are in the service manual or not but if you find a large variance then good chance there's an issue
Hah. That's probably a 10 minute job for him.Guy at the machine shop owes me a favor. Since its already there its best to completely rule out the it out before putting it back together. I will know the answer to the question latter this afternoon.
Carb
So give HIM one.He will not give me a price!![]()
So give HIM one.![]()
around here in working order not restored that would be a 5-700 machine depending on attachments, 100-400 needing work
800-1K restored and looking pretty
