I just purchased some treatment chemicals from Woodboiler Solutions and have a simple question. What is the best way to circulate the additive through the entire system? I was thinking I could manually open the lone zone valve and jump the thermostats that control each zone (6 total) to get each of the circs working. I'd let that process occur for some time then slightly open one of the lower drains. I suppose I would need to only open one of the drains to the point the make-up water coming into the system was able to keep up with the exiting water; otherwise I would risk having the circs run dry. Or, is there a better way to drain the solution back out of the system without the circs running?
Also, for those that need treatment chemicals I was very pleased with the pricing and assistance provided by Woodboiler Solutions.
Thanks.
Thanks.
