Thanks everybody for your replies. I was really hoping the PH would be able to pick up the slack, but it sounds like it is definitely the wood that is slacking. I loaded the stove up today and was able to get it up to 450. I tried closing the damper bits at a time and had the secondaries running like crazy, but it just couldn't get any higher. I am using an IR gun to check the stove top temps so I am assuming that is fairly accurate.
Maybe I'll try the pipe damper like Todd said and see if I can trap some more of that heat inside. I have about 4' of double wall black pipe inside and roughly 25' of class A running outside the house.
The way it sounds is the Mansfield and the PH are on the same level and there wouldn't be much benefit to switching over.
So if I was to run the class A chimney through the master bedroom will that add any heat to it? Or does the insulation block all of it?
Let me make sure I have this correctly. First I have to get better wood. Then add a pipe damper. Next would be changing locations. Last would be getting a new stove or a second stove?
Does anybody recommend a bigger better stove than the Mansfield that will put out more heat or burn longer and can last through the night?
Thanks again you guys, you are saving me some big $$$!
![[Hearth.com] Trading in a Hearth Mansfield for a Progress Hybrid [Hearth.com] Trading in a Hearth Mansfield for a Progress Hybrid](https://www.hearth.com/talk/data/attachments/122/122254-2c268c2beaddef99a37706be8ab465ba.jpg?hash=WwTFfHat0N)
![[Hearth.com] Trading in a Hearth Mansfield for a Progress Hybrid [Hearth.com] Trading in a Hearth Mansfield for a Progress Hybrid](https://www.hearth.com/talk/data/attachments/122/122255-83b711aa2e63f525ce45b1ef5cbd3f11.jpg?hash=YsmRghA5b3)
![[Hearth.com] Trading in a Hearth Mansfield for a Progress Hybrid [Hearth.com] Trading in a Hearth Mansfield for a Progress Hybrid](https://www.hearth.com/talk/data/attachments/122/122256-65ffd7c15026fb46c360fb198bbc8514.jpg?hash=hy9CHX-GHy)
![[Hearth.com] Trading in a Hearth Mansfield for a Progress Hybrid [Hearth.com] Trading in a Hearth Mansfield for a Progress Hybrid](https://www.hearth.com/talk/data/attachments/122/122258-a09c0af6b96c3ee9b72bbf17ba9a738e.jpg?hash=Z9etk5Ajtj)
![[Hearth.com] Trading in a Hearth Mansfield for a Progress Hybrid [Hearth.com] Trading in a Hearth Mansfield for a Progress Hybrid](https://www.hearth.com/talk/data/attachments/122/122259-a98c6515fac54741ae6dd9153378599e.jpg?hash=p_JZxvwCU_)
