Somebody was asking a couple days ago about buying this splitter,
Just want them or anyone interested to know.
lazeedan said:I trying to resist the temptation.
Kong said:Let me suggest that the first thing you do is check all the clamps (important) and bolts/nuts to see that they are tight. There have been a rash of new splitters from Huskee that have spit off their hoses and blown out a gallon of hydraulic fluid before the proud new owner could kill the engine. Don't be one of them. The only other complaint I've seen abuot them is occasionally the welds around the axle/hydraulic-tank allow fluid to leak. Any welder can fix it in a moment but you might want to keep an eye on it.
As to the low hydraulic fluid, don't let that happen. Air bubbles do high pressure pumps no good at all. Also the fluid will run a lot hotter if its low and then you won't be able to warm your hands on the cylinder without burning yourself. Bummer.
For whatever its worth I bought a 35 ton Huskee two weeks ago at Tractor Supply myself. It was a returned splitter. A guy bought it, took it home, started it, pulled the lever, blew off a hose, and squirted about 2 gallons of hydraulic fluid all over the place. He promptly put it back on the trailer hitch and took it back, got him another one and went away happy. The store put a new hose clamp on it and a tag that said $200 off the already reduced price, so it was down to $1,400 at that point. I saw it and said, "what have I got to lose?" and went in and offered the manager $200 less than that. He took it. There's only a 30 day warranty but I don't care - we've already split just under 7 cords with it so if it was going to break again it would have done it by now and it hasn't. Nothing will stop it. We have split/cut through elm crotches that were over 20" in diameter. What it will not split it simply pushes its way through; we have busted up some old stuff that was laying around the wood pile that I thought would never be split - never could be split to my mind. Amazing, simply amazing.
Kong said:Whoops. Something I need to tell you. This is important.
You see those two steel prongs that stick out to protect the retracted wedge, the ones that push off a stuck round of wood that doesn't split? Get yourself a grinder and round off the corners on those two things and then repaint them. I do not want to have to tell you how bad it hurts when you bang your forehead into one of them when you bend over to grab a split of wood, and you'll bleed like a stuck hog if you leave the corners sharp. Don't ask me how I know.
herman said:I got one saturday at t.s.c. 22 ton & yes it is very powerful. I did check the fluids all ok, checked all clamps all ok, but i will double clamp the hoses ,all nuts & bolts all ok, everything was ready to go xcept pulled the wheels to check the grease in the bearings & guess what, wasn`t any { xcept what little the bearing mfg. put on them} was that a surprise not really after reading some of the issues that some were having.
Both wheels were wobbling, when the nuts were put on the axles they were just put on loose, so greased up the bearings adjusted the nuts put in pins, added slime to the tires checked air pressure, were good to go........
Now i have a question on some 22 ton units the log cradle is made from angle iron & other units are made withlike a C type channel { see the pix } what is the difference. ??
Also on the foot plate the letter " H " is welded on ,is that something new or for strength. ?? { See pix }.
Got to get a work table. Has anyone else found the bearings to be dry. ??
Herman
