Worse yet some pour souls paying $7 plus for per gallon of propain.
LOL...clever misspelling. I'll be reusing that one.
$542. That would have gotten about 2 and half tons of pellets here. With the forecast here of seven days of below zero nights an hardly making it to teens in the day that fill of gas would be getting a major venting.I just paid $2.71 for a gallon of proPAIN today! Picked up 200 gallons & makes us to 60% in our 500 gal tank. Paid $3.67 a gal on 1/30. 1/20 it was $5.26 a gal but we didn't order any. 12/2013 we paid $1.87 a gal & 12/2012 we paid $0.98 a gal.
We just installed our pellet stove so we'll be tracking our savings closely!
Way better then saying "Total oil Usage is Ridiculous!".... Since most who heat with pellets heat their houses warmer, a generally accepted formula here is "one ton of pellets = 120 gallons of oil" so the only thing "ridiculous" is how much BEER you can buy with the savings![]()
If you are going to use 5+ tons this year, then I'd budget for 1 ton less next year, maybe buy 4 tons, and then pick up bags during the season if it looks colder than 4 tons will handle.Or maybe not? This is my first winter with a pellet stove as it came with our first house purchase. When it is all done and said, I am looking at having gone through 5+ tons of pellets (sole source of heat - didn't use a drop of oil!). Summary of pellet usage:
1 Ton Turmans
2 Tons Barefoots
1 Ton North Country Power
1 Ton Cubex
This will hopefully get me into the warmer end of April but I may need to supplement with a few bags here and there as the supply dwindles down. That said, I am beginning to budget and plan for next winter so I can stock up during the cheaper summer months. Can anyone give some idea on how many more pellets they went through with the brutal winter we have had, compared to earlier heating seasons? I am not looking to buy 5 tons for next winter and only go through 3 - my basement is big, but I do not want to eat up a lot of real estate storing pellets all summer long.
Thanks for any insight provided!
I have 3 heat sources Pellet as the main heat, Propane as a backup and when it gets warmer a heat pump will take care of things, I have about 2 weeks of pellets left and hoping that the weather becomes more seasonal soon (Heat Pump works above 30 degrees).Arti, hope your not paying extra to burn wood pellets![]()
I was hoping your were tapping into a locally grown resource that is cheaper than pellets to feed the Countryside. It was designed for corn. I think the price now is around $150 tonI have 3 heat sources Pellet as the main heat, Propane as a backup and when it gets warmer a heat pump will take care of things, I have about 2 weeks of pellets left and hoping that the weather becomes more seasonal soon (Heat Pump works above 30 degrees).
If the weather doesn't moderate then I guess extra pellets are in the budget.
The heat pump is the most economical but hasn't not seen much use this year. So I might pay extra to heat with pellets.
I live on a farm however the corn seems to leave a sticky residue on everything and burns hotter so perhaps it would shorten the life of the stove. Also have a St Croix scf 050 sitting in the shed that I may hook up if pellets get to pricey.I was hoping your were tapping into a locally grown resource that is cheaper than pellets to feed the Countryside. It was designed for corn. I think the price now is around $150 ton
To put this in perspective with numbers:
To get the same BTU heating value of pellets @ $250 a ton the following fuels would have to be priced @,
Wood = $275 per cord
Corn = $4.95 per 50lbs
Coal = $370 a ton
Oil = $2.11 a gal.
LPG = $1.50 a gal.
NG = $1.60 per thermal unit
Electricity = 6.50 per KWh
Since coal is 1/2 that cost for you, it's a no brainer over pellets. Actually, I don't follow your reasoning. It should say 'if I want the same amount of btu's as I get from $250 worth of pellets, how much would I have to pay for the same btu's from other heat sources?' Coal sure wouldn't be $370! The whole concept hurts my head and I'm going to bed thinking about it! Thanks a lot!To put this in perspective with numbers:
Coal = $370 a ton
Oil = $2.11 a gal.
LPG = $1.50 a gal.
Hey, this value is closer to $00.59 by my calculations. I'm sure that's what you meant.... $ 00.65Electricity = 6.50 per KWh
Since coal is 1/2 that cost for you, it's a no brainer over pellets. Actually, I don't follow your reasoning. It should say 'if I want the same amount of btu's as I get from $250 worth of pellets, how much would I have to pay for the same btu's from other heat sources?' Coal sure wouldn't be $370! The whole concept hurts my head and I'm going to bed thinking about it! Thanks a lot!![]()
Wood is not free. There's also no such thing as a free lunch. It saves on a gym membership..and there's nothing like the smell of a 2 stroke in the morning.wood is free if you do it smart .. if you are in town .. look for tree crews taking down say a huge 5ft diameter Oak
offer crew chief a place to dump wood closeby for free. he saves man hours hauling wood to dump that could be used to take down Oak.
main drawback is you've got to be able to handle HUGE logs .. combined with need to quickly bust down all the wood. since it's in your front yard.
this is where Stihl 084 with four ft bar earns it's keep. 35ton splitter is a requirement.
Oh no... Its frustrating to discuss this subject with a "wood burner" There seems to be some here who are able to harvest wood for "peanuts" Its been several years since I have burned wood, but I remember having to purchase ....Hi test fuel(anything less is risky) for my saw(stil 361) and my splitter (28 ton) and my truck(obviously reg fuel). This combined with chains, bar oil, 2 cycle oil, chain saw bar's, gloves, gator-aid...and other costs (time being a major contributor) I was un-able to avoid or exaggerate to the LOW side.Wood is not free.
I was home so many days due to the weather and could run my insert more than usual.
I also have all the equipment . How many times do your hands touch that wood before it goes into the stove to become"free" heat? Take the time to deal with getting a season worth of wood. Now think hard. Go to work at your normal job for those hours. Now you can buy some pellets and not have ants spilling out of that choice piece of cherry all over the floor. It's the love of the game I questsquestsOh no... Its frustrating to discuss this subject with a "wood burner" There seems to be some here who are able to harvest wood for "peanuts" Its been several years since I have burned wood, but I remember having to purchase ....Hi test fuel(anything less is risky) for my saw(stil 361) and my splitter (28 ton) and my truck(obviously reg fuel). This combined with chains, bar oil, 2 cycle oil, chain saw bar's, gloves, gator-aid...and other costs (time being a major contributor) I was un-able to avoid or exaggerate to the LOW side.
I have also in my wood burning career..(off and on I have burned wood 30+ years)... Add 1 new chimney(long time ago...forgot how much $$) 2 chimney fires (second cost me a SS liner $$$ ??) as well as the mess...
I forgot the "bugs" they all seem to "revive " when brought insideand not have ants spilling out of that choice piece of cherry
I just went to the top to make sure this was a pellet forum...as apposed to "boiler forum" Some of the "old time wood burners" look down their noses at pellet burners....Like I did before I "changed"I also have all the equipment . How many times do your hands touch that wood before it goes into the stove to become"free" heat? Take the time to deal with getting a season worth of wood. Now think hard. Go to work at your normal job for those hours. Now you can buy some pellets and not have ants spilling out of that choice piece of cherry all over the floor. It's the love of the game I questsquests
