Just cause the first question you guys ask is what is the compression!
So were to get a decent priced Compression tester?Compression test is easy, inexpensive, and tells you in about 5 minutes if you're wasting your time or not.
This is the same set I own, I paid about $50 for it 10 years ago.So were to get a decent priced Compression tester?
Check local Sears not impressed To much $.
Will try an Auto Zone.
Sean
Special order around $70 @ Auto Zone.
.....well, i just read this older post(at work) and did a stock check, i found some APEX T27 bits in our ''non-stock'' items....about 1" long.....would work nice in a magnetic bit holder.....bit holder may not fit into tight spots thoBuy this Wiha tool kit for starters: http://www.baileysonline.com/itemdetail.asp?item=WTK&CAT=
If you can find a T27 bit for a drill (Stihl is T27, not T25), do let us know. But the t-handle one in the Wiha kit seems to work really well, even if a drill-mounted one might be a touch faster. From there, a pressure/vac tester wouldn't be a bad idea. A tachometer and compression tester could be added in, too. If you end up needing a clutch tool, you can probably make one out of a junk socket for most saws with external clutches.
You're right about the tight spots. For removing covers and similar parts, any torx bit or driver should get the job done; however, the longer bits (like 6") are needed to go through the length of the cylinder to reach cylinder bolts.
thanks....im'a take a looksie for some 6" T27's.....if i can't find any, i'll check your link....Here's what you want. I bought a pack of the same ones last year, kept a couple and resold the others. They're good quality and cheap.
Some go by feel, but I use a torque wrench to tighten cylinder bolts. To get to the bolts, you often need a long torx bit. Wiha has some 6" bit sockets that do the trick:
http://www.wihatools.com/700seri/771Sockets.htm
(Or for use this with adapter: http://www.wihatools.com/700seri/745se152.htm)
