Just trying to kick up some flames for the pics.bogydave said:webby3650 said:Ok, here is a close up.
Time to close the bypass
Great looking hearth.
Good stove. The blowers really help (just a tad noisy though)
I am happy with mine.
I have installed both the Ultra and the parlor, I was not impressed with stability of the legs, they have a bit of give to them. I also intended to use the blowers, therefore I like the convection deck and side shields.Beetle-Kill said:Thing of beauty. The hearth, not the stove. The stove needs legs.
webby3650 said:I have installed both the Ultra and the parlor, I was not impressed with stability of the legs, they have a bit of give to them. I also intended to use the blowers, therefore I like the convection deck and side shields.Beetle-Kill said:Thing of beauty. The hearth, not the stove. The stove needs legs.
NATE379 said:I like the ultra better than the parlor. It's a bit taller so that means less bending to put wood in![]()
bigbluebus said:I like the King but I would also need a cook surface for tea pot, steamer, etc.
I see that the ultra does not have a big enough cook top for this. Does the parlor have a larger cook top?
north of 60 said:By Curious George, I think you have got it!
The give seems to come from the body of the stove, not the legs. I foresee no future failure due to this, it has a half inch bolt in each leg. I thought I wanted the legs before I saw them in action, I am glad I went with pedestal. I have never liked blowers, but I gotta say, I like the way this heats, it's a very even heat, not a blast of heat in one part of the house. I haven't tried out the ash pan yet, It's only been about 4 days and see no where near enough ash build up to even consider pulling the plug on it.(Curious) George said:north of 60 said:By Curious George, I think you have got it!
Thanks North of 60, your friendliness goes a long way.
Can you say more? Do you have durability or functionality concerns with the legs (e.g. wobbling to loosen the flue), or do you just not like the feel?
I'm deciding between the Classic and Parlor (don't want shields), and was leaning towards the Parlor for looks and height.
Do you still have the King or did you replace it with the Ashford? Which one do you like better?
When I had the King, we were trying to heat this entire 70's L shaped ranch from the far end. I only sold the King because I needed the cash at the time. After it was gone is when I decided to add a second stove in the middle of the house. What a difference it made!
The Leyden was a turd, the Cape Cod did the job just fine. I still needed a stove for this far end of the house when it was real cold, after seeing how good the Ashford did I decided to swap the cod out. The CC made enough heat, just not for the entire day, I was just tired of coming home to a cold house! Its the best move I have made so far!
You can't ever go wrong with the King!If I can convince my wife to go with the King, I'll do that just to be on the safe side.
I found this hilarious. Thanks for bringing up the old post.Thanks, this is the 3rd and final stove to go on this hearth.
Oh ya. Maybe this will be the Oslo will be my last stove?I found this hilarious. Thanks for bringing up the old post.
