This may be more appropriate for the Osburn forums, but I believe that this is likely to be more of a general question draft related question than an Osburn specific problem. My Osburn 3500 is struggling to keep up the heat in these negative temperatures and I can rarely get the house more than 72 now that it's wicked cold out. It's rated for 3000sqft and my house is only 1700, so it's oversized for the house to begin with and should have no problem keeping up. I know there are a lot of varying factors with this, but I think something else is going on. It was installed professionally this spring. When it's in the 30's, I have no problem keeping the main room in the upper 70's, which allows for the rest of the house to be high 60's or 70's also.
Some weird things I've observed. My top plate has never once gotten over 437 degrees regardless of where my air control is, even when my flue temperatures are at 1000 using a probe thermometer 18" above the pipe. MC of wood is 14-16% or less on average mixed with 10% occasional softwood, so I know it's not a wood/moisture problem. I've used about 8-9 face cord since October, and this winter all things considered has been extremely mild. If I cut the air control completely when I've got relatively full load or am accidentally over firing the flue, the fire dies down, but never fully dies out, simply slows down. Dollar tested, gasket is fine. Hardwood oak loads of 6-7 splits and rounds 4-5" in size loaded N/S burns from start to coaling phase last 4-6 hours depending. Blower is virtually always running on high, which may cool the stove top some, but I doubt it would cool it anywhere close to temps I'm seeing others report on their wood stoves.
I've never once packed the stove full like some of the pics I've seen here, as I'm very concerned I'm going to overfire the flue if I do, even if I'm running the air at 30% or less. Last night I loaded up 1/3 worth of coals in the stove with 4-5 hardwood splits and I was rocking 800 degree flue temps with my air at 10% and top plate running at typical 430's. I woke up 6 hours later to coals and running propane unfortunately.
Chimney if I had to guess is about 20-25 feet straight up (two story house), double wall uninsulated until it reaches the ceiling, then double wall insulated the rest of the way up. Double wall had to be used in the house because the install was slightly too close to the wall, which may potentially complicate my fix.
The stove manual recommends not having a flue damper if I recall correctly ( i need to double check this), and it appears that Duravent doesn't make a barometric damper in double wall, so if I did get one, it would have to be a manual as it appears that's the only option I have. I'm not sure how to remedy this other than going against manufacturer suggestions if this is indeed the problem.
I guess my questions are multiple:
Does this sound like an overdrafting problem?
What's the best way to fix it?
If the damper is my only solution, since I've drilled a 1/4" hole in the telescoping pipe for my flue thermometer, in order to fit the damper, it would shorten the length of the pipe to where the hole would be inside the next section once reinstalled. Is this going to be a problem or am I gonna have to drop a few hundred bucks to replace that section of pipe?
As always, thanks for the help![Smile :) :)](/talk/styles/default/xenforo/smileys/grin.gif)
