Today's project Harman Accentra Insert Rail Kit
Took 2 weeks to try out the rails but it worked great slid out so easy on the metal instead of wood and had plenty of room to work on the stove here are some pictures so It DID happen :)
  • [Hearth.com] Today's project Harman Accentra Insert Rail Kit
thanks
I see you got a helper:)
That's Effen' awesome!
Considered your deign stolen..
Great job
Reactions: glenc0322
Just one question are you able to slide the 1 1/2" strut under the stove without lifting the stove to get it in? I am looking to get a used Accentra and am trying to figure everything out before I get one.
Yes slides right in between the bottom of the insert and the metal frame of the housing no lifting involved Mine is 1/4 inch higher so when I push it back I lean it a tiny bit to go back on the rails on the frame
Here Is a quick drawing (QUICK) of the dimensions of the kit I built If anyone wants them
around $70-$80 dollars you would need 2 10 foot sticks of unistrutt at $20 each 4 kindorf knees @ $3.00 each a dozen spring nuts washers and bolts around $15-$20 dollars. rough estimate you can get everything at home depot or lowes. Its alot cheaper to make it out of 2X4's but fr me it was hard to slide it out If you want the dimensions that I used let me know. And if you want to see the stove on the rails wait until Sunday
Looking at the picture you will need 1-10 ft stick of 1 1/2" and 1-10 ft stick of 3/4" also the 55" will vary with the height of the hearth since you are using the 1 1/2" to support it. You can also double up the excess 3/4" unistrutt (kindorf) if you do not want to lose the length of how far your stove comes out. Just trying to save some money without buying more unistrutt than you need. Some people actually have to pay for their materials ;)
Very good idea, like it a lot.
thanks
Even if I had to purchase the material I think its well worth the money to use metal instead of wood. But free is better
So what do you think?
I think it's awesome Glen... So much that I built one over the weekend using the info in this thread and it worked like a charm! All said and done the material cost $158 dollars from my local hardware store.
Here it is in action yesterday... :)
(broken image removed)
Way to go guys - saved between $500 to $350 (not factoring time) :cool:
Glad it worked I love it and saves a lot of money
I would slide the rail kit into the fire place a little more so it is a little more stable but Mine works great I should patent this lol
Used the home made rail kit again to pull the stove out for a quick cleaning and dusting. Works great
