how about traipsing out there with a deep cycle battery in hand and hooking it up to a power inverter to plug your tractor into for an hour or so? OR park this thing in the garage and throw wife's car into the barn.
you darned people and your fancy math. lol. So most batteries would crank out (i dunno, cause i've never checked) something like 100Ah at 20 hours, so you'd only get yourself 1:15 of heating time. I think they say to plug in your diesel truck about 2 hours before running it, so you'd be close, but it's probably not good to drain a deep cycle that fast. I dunno.Highbeam said:A block heater is usually around 1000 watts of 110 power. If you divide 1000 by 12 volts, you need 83 amps from that battery. Consider that leaving your headlights on is only about 9 amps of draw from a car battery, so running the block heater would be like powering 9 cars worth of headlights. It would knock that battery out in no time and you'd need some hefty cables. Also, the heater needs to run for several hours before it will warm the engine. You're better off with a small genset IF the tractor is even equipped with a block heater which is not likely.
I wonder what ever happened to the OP.
leftyscott said:UPDATE:
Went out yesterday and came back with some diesel 911. Put 16 oz. in a full tank. Saw on the directions to dump some in the fuel filter. Did not do this as i did not want to mess something else up. Anyway... damned thing wouldn't start. Same deal happened a couple weeks ago. Soon as it warmed up some, it started fine. Needed a jumpstart also as tractor hasn't been run in 3 weeks.
Seriously considering bringing it down to the garage.
Note to wife: Sorry honey, you're car's gonna have to sit outside for the remainder of the winter. Don't worry, it's a Honda and tthe heater works great!
leftyscott said:I'm not sure if my Ford 2600 has glow plugs or not.
Pragmatist said:and your barn is way overdue for some electricity ;-)
The tractor we are talking about is a 38 horsepower 3 cylinder diesel. A 1500 watt heater will bring that up to a startable temperature in 2 hours when you are talking about overnight temps down in the 20's. There is nowhere near as much thermal mass as a 7.3L 8 cylinder engineHighbeam said:Block heaters take longer than 2 hours to do the job.
This is why I like the "hokey" tank type heaters, you can feel the output hose and see if they are working. The block won't get warm to the touch like when it has been running.Even when they are working don't expect to feel the heat on the engine.
you will see the DIY guys with these hokey tank or hose types and you will see more pro installs using an actual OEM freeze plug type that replaces a freeze plug with the block heater so that the electric element is right next to the cylinders in the water jacket.
