dyerkutn
Oh thanks--I did not notice that---I see there are a whole bunch of old threads on measuring flu temps--I will read through those.This thread, though, is about stove top temps.
With the Castine, I can push a balled up wad of aluminum foi in the underneath air intake - have not had to do it yet, but I have learned where the intake is and I have the balled up foil that has been tested ready to go. I have heard of some that use a large magnet to cover the intake, but I would not know where to find one of those.Thanks for the responses. I'm glad I didn't load up before bed. I left it as it. When I woke up, the stove was cold, and there was nothing but ash left. But the house was still warm, 68 degrees. Hopefully by winter, I'll get my timing down.
Ok, now I'm going to divert on my own thread a little. What if I did load up and had a run away situation? Is there anything that can be done to help bring the temps down? Fan on full blast? Damper open or closed? Open the door and throw in some wet paper towels? Thanks.
We have had the same problem, you come home from work and want to load the stove, but if you do, it won't make it all the way to the AM if it's really cold out but it won't be burned down enough to reload before bed.
Well, Tony, I have the Progress and have had it climb up to the upper 600s thanks to the cat eating too much smoke. The more you damp it down, the higher it goes. Sweating bullets, literally and figuratively... How do you control things in that situation?I'm not suggesting everybody load a hot stove, but I can tell you I have done it numerous times with absolutely no problem, and I checked with Woodstock and they saw no problem. It seems these stoves simply have sufficient air control.
Dennis, I learned from the best!![]()
No, Dennis. I think he means you... And rightfully so.And of course you are talking about one Tom Morrissey! He will appreciate that.
When you get older, there won't be a "final reload" for overnight burns....you'll be getting up in the middle of the night for a "nature call", and throw in a piece or two like I do![]()
When you throw in a piece or two in the middle of the night, do you just leave the air closed down? I'm assuming you aren't going to stay awake and mess with air adjustments in the middle of the night. I'm still trying to learn some of the tricks. Thanks
You shouldn't need to reload that Summit during the night, should easily burn through without needing wood. That's one of the stoves that I'd still like to test drive in my home.
I stay with it for about 15 minutes.....gotta walk the dog too....he's a senior alsoWhen you throw in a piece or two in the middle of the night, do you just leave the air closed down? I'm assuming you aren't going to stay awake and mess with air adjustments in the middle of the night. I'm still trying to learn some of the tricks. Thanks
Well, I'm not speaking for Tony for sure but I think you know my thoughts on this one. 600 degrees is a long ways from making me nervous. And yes, when you get the high temperatures, that stove top can get hot. You might remember the story about when I found my wife standing at the stove opening and closing the bypass because the stove top wanted to go over 700. I found she had closed the draft. So I simply went over and opened it to 1 (25% open) and the stove top did as expected; it cooled down and did not go over that 700 mark. So many times on these stoves it is good to give more air rather than less.
