I'm not sure what batch burning is.
Fill - burn down to coals - repeat. This instead of adding a few splits at a time.
Oh. I just call that "loading the stove."Fill - burn down to coals - repeat. This instead of adding a few splits at a time.
Same thing here Dennis,,,,must be a Fireview thingI don't watch it get to peak at all. Put the wood in, wait a few minutes, engage the cat and go to bed. End of story.
....they just built them right
Same thing here Dennis,,,,must be a Fireview thing....they just built them right
Heck noIt's a BK thing too but we're disqualified.
At cat is a cat
We should start a club, although BAR gives me the impresson that his is far more drafty than mine. The oldest and largest part of my house is still completely un-insulated, plaster applied directly to stone walls, and my heating bills are not that bad. My annual oil usage is only 1400 gallons, and the tax man claims I'm heating 5500 sq.ft.
I dream of being one of the people who can warm a room on 3 splits in my Fireview, but I think I'm a more likely candidate for the drafty antique house club.
Ok that's 3 of us, Browning makes 4. There are others too - Danno has an old stone victorian something. Then there is eclecticcottage and a few others that slip my mind at the moment. (Edit - and just reminded of jimxj2000)
We could try and be all cool with different levels like Scotty's club and the pellet pigs. Make up a formula that scores points based on house age, how little insulation you have, how many chimneys, if you are using an epa stove. Bonus points for a smoke dragon or anything from Vermont castings. More bonus points if you still use your open fireplaces. Even more bonus points if said fireplaces pre-date Rumford.
And even more bonus point if your primary/alternative/backup heating is some no longer installed sytem like steam or gravity hot water, double bonus if its something really unusual like a vacuum vapor steam system running off a snowman converted coal boiler..
Oh... and I'm surprised to see a few people post recently that they cut air back before engaging the cat. What's the theory on that? I always burn full throttle until stove top is over 500F, engage cat and wait to be sure it lites off, before ever lowering the air at all.
Loaded the stove to 80% at 10pm. Still watching stovetop thermo, and should be ready to engage cat by 10:35pm. Should be headed to bed before 11pm tonight, unless things go horribly wrong.
I found the same thing with my Fireview on a reload,,, cutting the air back waiting for the stove top temp to climb. I try to catch the stove top at 250 to reload if I'm around. Makes for a quick turn around on engaging the cat. Wood burning is not about rushing anyways,,,, it's to be enjoyedI find that if I leave the stove air fully open (both with the PH and with the FV before) that the fire rages a bit too much in the firebox and the stovetop doesn't really heat up as fast. Cutting it back a bit once going well seems to slow the flow down a bit and allow it to heat more with less fuel consumed... maybe it is a perception thing, but in any case I don't like to see my flue temp rising out of control waiting for the stovetop to get up to cat temp. It certainly hasn't seemed to increase the wait any.
..........CharlieDon't forget mgflickman. I think she has an old house, too.
I'd be interested in seeing your scoring system, and guarantee I'd win on chimney count alone. I have counted eight thimbles, three fireplaces, and five chimney stacks, but still don't have a handle on how many flues there actually are between those stacks and thimbles.
I think it's a matter of finding that sweet spot according to how much and when your loading your stove, with your walk away draft setting... It's funny , even with the Fireview,, things can look not good, not enough air and then 30 minutes later I'm glad I didn't touch a thing....it's burning great. I think the big thing is having the time to sit and watch what happens with your stove,,, when trying something new. The learning curve is all worth it down the road. It's just putting in the time and being aware of outdoor temps, etc.This is a great thread, so many good ideas. I'm going to try to do a smaller reload in the afternoon - following the 1 split/hr guideline and see how that goes. I'm also thinking I'll work my way up to adding some wood to a fire that has not burned down to coals by trying the turn down the air, open the bypass, put in the wood, crack the air and re-engage the cat in a bit process. I've just not had good luck with adding wood on anything too hot, even too big a bed of coals, because I start getting crazy secondaries and it just seems to go downhill from there. But I'll try inching my way up to that, because it would be so handy to be able to put in wood when I want, at times (such as when I'm not going to be around when it burns down to coals), to extend the burn cycle to when I will be back home. Thanks to all for sharing their tips.
