Backwoods Savage said:Okay Jay, here's a tip. Split vertically.
Jags said:Tip: don't stick a bees nest in your coveralls.
Hey Jay, why you gotta lube wood bits?? (serious question). Are you getting wood burning??
smokinjay said:Jags said:Tip: don't stick a bees nest in your coveralls.
OH YEA....Walnut will burn hackberry hickory. Now also talking forsner bits up to 3-1/2 inchs, and tennon makers is what I am doing. lol
Jags said:smokinjay said:Jags said:Tip: don't stick a bees nest in your coveralls.
Yeah, I use those bits on occasions to, but I don't get a burn from them. Hmmm...maybe sharpness??
smokinjay said:Jags said:smokinjay said:Jags said:Tip: don't stick a bees nest in your coveralls.
Grab a piece of walnut a 3-1/2 er and set the video up......I want to see this! Even the smaller one will drive faster and a cleaner hole with the lard.
Jags said:smokinjay said:Jags said:smokinjay said:Jags said:Tip: don't stick a bees nest in your coveralls.
Oh - I don't doubt you a bit. I was just thinking that I punched two holes with a 2" on some oak (making a couple of sliding drawers) and now that I think about it, there probably was a little burn on the edges, but I was also thinking that the bit was dull. Maybe I don't pay much attention because I always have to hand finish sanding.
Got any tenon makers you wanna send to me??
smokinjay said:Try it....Now with tenon making it makes even more of an improvement. This is a trick out of metal shop for sure, but sure helps in wood as well. (My forsner are brand new) Not the best quality though.
Jags said:smokinjay said:Try it....Now with tenon making it makes even more of an improvement. This is a trick out of metal shop for sure, but sure helps in wood as well. (My forsner are brand new) Not the best quality though.
I don't remember the brand, but mine are probably 40 yrs old.
I had often thought of trying my hand at some log furniture.
Tip: if working in a cool/cold shop, carry the wood glue in your pocket to keep it warm.
Thistle said:One old trick our ancestors did was have the tenon dry & mortice a wee bit green,it would then shrink up tight.Lock in place with a tapered dowel or peg,then cut off flush.
bogydave said:Quick miter grove clamp.
Get a 3/8" washer that just fits in the bottom of the miter slot, countersink one side of the washer with a 1/2" bit, epoxy a flat head 1/4" bolt to the washer, clamp in miter slot till dry. Tighten wing nut snug to hold jigs, feather boards etc.
bogydave said:Sand paper cutting jig.
Draw a line on a board or piece left over MDF 6" X 12" from the edge as wide as your sanding block.
Screw a hack saw blade to a board with the teeth along the line.
Slide the sandpaper under the blade to the edge of the board & tear it off.
The Right width every time.
