My understanding was he left like a 1/2" gap top and bottom to allow some convection to take place, it shows in one of the photos. Just to be sure, I'd probably want to drill a temp probe in there to take some measurements while it's running hot for a while.Might consider tapping a bottom and upper vent into the chimney cavity.
I ran into the same situation with my wife wanting a fireplace in our log home. I / we settled on the Hearthstone Mansfield, for its size and the large fire viewing glass. This will be our primary heat source with a propane fired radiant floor heating system for back up. We will have a basement to roof , stone chimney that is located all within the house structure . She likes this plan but always brings up " how can you build a loghome without a fireplace"Great, thanks! This is the reassurance i was looking for. I became concerned when i got into a battle with a local fireplace store about the install. I was shocked by their ignorance, arrogance, and contempt for my install. He laughed at my Woodstock Fireview and said i shouldn't buy a no name stove. Not to start a debate, but in my opinion, Woodstock is the greatest company in this country! How could they not know Woodstock? I left and will never go back. Too bad, i wish i had a local wood store to go to.
Anyway, to answer a few questions - Yes, heat transfer is also a concern of mine. I hope the ventilated non combustible wall will dissipate enough heat.
The purpose of the wall is this - The WIFE! She wanted a fireplace with a mantel and I want a wood stove! I told her i could hide the chimney behind a wall and install a mantel. Yes, due to clearance issues, the mantel will be kinda high, but.whatever... it's there!
I have pictures of the install and will post very soon. Thanks, and stay tuned!
I suspect that 1 1/2 inches should be fine . . . but I've shot a note to a co-worker/friend who does concrete countertops as a side job (actually he keeps pretty busy as a firefighter/paramedic, oil delivery guy, concrete counter top manufacturer/installer and fire science instructor).
If I provide the answer though will you then show us a pic . . . I really want to see this ugly hearth . . . it's like those pics of the ugliest dogs . . . you just have to look at them . . . and sometimes they're just so ugly they're cute.
haha... thanks for the info! No pic of the carnage for you or anyone. But i'll tease you more with this added description - To make it worst, the hearth top stones were slightly twisted so the morter lines were on a angle. When you sat on the couch you could see the crooked lines. Oh, and the hearth face, or toe kick, (whatever you call it) was made up of leftover small stones.My wife called them chicklets... seriously, i'm really embarrassed. I'll include a picture as is stands... if you look close, you can see where i removed the cemented stones. Use your imagination!
When you are finished with the hearth aesthetics, I would like to see pictures of the class A to stove connection.I'm running class A chimney straight from the stove
Fortunately where you are at currently you can change the hearth floor finish material to something you like more. I agree with contrast on fireplace and hearth. Your stone back walls look super sharp so your on the right track
p.s. I'm finding the Fireview to be a nice little stove, easy overnight burns and quite capable for its size - heating ~2250 sf 2 story with mine
The adapter makes sense, wasn't quite sure how you were going to pull that off.Hey, nice setup! Sounds like your house is similar to mine 2180sqft colonial (excluding my 340sqft bonus room addition). So it heats your house well?
I should be a bit more clear - the chimney will attach to a stove pipe adapter (which is attached to the stove). So technically, the chimney is not attached directly to the stove. There will be a inch or two +/- of stove pipe.
I would pull the baffle and run a rotary cleaner right through the stove and up to the top. Then vacuum out the dust that falls into the bottom of the tee.How do you clean a chimney like that which doesn't have an accessible trap?
