Hello all! New to this site and looking for opinions on an MS 250. I will be using it as a back up/limbing saw. I have a 357 xp for doing the bulck of my cutting. Price, performance and weight are my prime concerns. Thanks for the help!
Back when they sold for $299 with the 18" bar, the MS250 was hands down the most saw $300 would buy. They are out of production I believe now but there are still quite few in the dealer and distributor inventories. They are simple, powerful, and reliable but the newer designs eclipse them for ergonomics, air filtration, and fuel economy.Hello all! New to this site and looking for opinions on an MS 250. I will be using it as a back up/limbing saw. I have a 357 xp for doing the bulck of my cutting. Price, performance and weight are my prime concerns. Thanks for the help!
I purchased one also for $299, It's a BIG bang for the buck! I was just in the Stihl dealer this past weekend, I believe it went up to $339, I would still pay the price for that saw, It's worth it.Back when they sold for $299 with the 18" bar, the MS250 was hands down the most saw $300 would buy.
The price bump makes it a lot less attractive against the MS251. So many 21st century improvements to the MS251. Addresses the 2 big weak points of the MS250, Anti-Vibe and air filtration. Of course the MS251 has yet to overcome the 20+ year legacy the 025/MS250 has laid down.I purchased one also for $299, It's a BIG bang for the buck! I was just in the Stihl dealer this past weekend, I believe it went up to $339, I would still pay the price for that saw, It's worth it.
This is truth. Stihl RS chain in .325 is some seriously decent chain.I didn't really fall in love with mine until I ditched the stock chain. Get a semi or full-chisel chain and you won't be disappointed.
I have owned a lot of 0250s. They worked OK for topping and limbing, but I would not consider them a firewood saw. Compared to an MS361 or 357xp... well, there is no comparison. I later ditched my 0250s as limbers for 0260s and never looked back. As said above, AF and AV are not so great on these, nor is the optional dial chain tensioner. I also ran mine with 3/8 low profile/picco for faster cutting, as they did not pull .325 as well.
As for the newer 251, people seem to be complaining about the 251 starting and flooding, but that is a common Stihl trend. I have never run one so I do not know about them in particular. I have a 211 (I have owned 3 of them) that some people also have had problems starting, but my 211 starts just fine. I think that people need to learn how to tune them better (especially at the dealer). The 211 and the 251 have far better AV and AF, and they are strato (air) charged for better gas mileage and they burn cleaner. They 251 also has white a plastic handle, which are far better than the orange handle 0250. O/w they weigh the same and have the same power. For $30 more, I would buy the 251 over the 250 myself, if for no other reason than the AV (250 has 5.7/6.8 m/s*s vibration vs 251 which has 3.9/3.9 m/s*s).
if NO burp bump to "fast idle" anyway( after 3-4 pulls)
saw will start.
for some reason the burp is difficult to discern or hear. saw floods easy so after the 4 pulls bump to fast idle w/o burp.
Im not sure if and what changes were made to the 251 carb wise but the 250 is the one saw I own that has its own starting procedure. many I have owned seem to need to start the same way.
saw on full choke
pull 3-4 times MAX
if saw burps before 3-4 pulls bump up to "fast idle"
saw will start.
That is typical on a lot of Stihl saws, which are notorious for flooding. I had/have the same starting procedure on the 025, 026 and the 361. I usually do not use the decomp button on my saws that have them when starting cold because they tend to flood more using them (miss the burp/pop/whateveryouwanttocallit).
I've had my MS250 for about 6 years now and would buy another. I've probably cut around 50 cord of firewood with it, not to mention all the limbing I've used it for, and it runs as well now as it did new. Keep a clean air filter in it, change the plug every couple of years, keep the chain sharp and it will do its job.
You cut 8+ cord per year with a 250? You have the patience of Job.
As have I, about 80% of my wood is Maple and I had some good size rounds; just did a cord last night with the 250, not monster stuff but some 12"rs in there.I scrounged up 6 or so cords with my 250
Well, I guess I didn't tell quite the whole story - I also used the 170 some.
