Todd said:I agree if you burn 24/7 a cat stove is the way to go. I recently took the plunge to a cat stove and can honestly say I wish I had done it sooner! Comparing my old Homestead to the new Fireview, I now have longer burns with more heat and consume less wood.
I can burn this stove on the lowest setting and maintain a 600 deg stove top temp. I had to run my Homestead at a medium to medium high setting constantly stoking the fire to maintain that temp. So there is an obvious wood savings there.
Ease of operation. I think there is not much difference except another lever to engage the catalyst. You have to tweak dampers, and monitor temps on either stove if you want them to burn correctly.
As far as draft, I was worried because my stove has 3 ea 90 deg elbows, an outside brick 22' chimney with s/s liner. But this stove drafts better than my old one and it had 2 ea 90 deg elbows. So I would guess if your current EPA non-cat stove drafts good a new cat stove should to.
Maintenance I haven't had to do on my new stove yet, but it doesn't look too difficult to unscrew a couple bolts, lift out the cat, and clean or replace as needed. A properly operated cat should pay for itself over time.
Maybe someday they will have a top loading soapstone stove with a grill/rotisserie option. That would be awesome!
Todd, on the Keystone, you can clean the ash from the combuster from inside the stove. There is a 1/2 inch (socket) bolt inside the door. Remove that, then the grate will drop down and slide out. Easy to vacuum off the cat to remove the built up flyash without removing the combustor. A five minute job. Not sure about your Fireview, but worth checking out.
