BeGreen said:BrowningBAR said:Franks said:Your the guy with 2 stoves right. I remember now. I would say you would be THRILLED with the Heritage. Do it within the next couple of weeks. Hearthstone is having a 10% off sale. In fact, go buy it today so you can claim the rebate on your 2010 taxes and get your cheese back faster. Go go go hurry!
Well, it's more like 1.5 stoves with the way the Intrepid is performing.
What about the Phoenix and the Mansfield? Specifically the Phoenix. It is a bit bigger. What type of difference will I see/feel?
I'd get the Mansfield. It should cover the area well enough to remove the Intrepid and forget about it or put in a cooktop stove like the little Napoleon.
Not on the list, though I can also recommend it, is the big PE Alderlea T6. It won't drive you out of the room unless you let it. This is a very flexible. simple and easy to run stove.
That surprises me. The PE is a BIG cast iron stove. What type of usable burn times do you get out of it? And for this instance a burn time is a temp of 350 or higher. The square footage and BTUs rating are greater than the Mansfield, yet it has a smaller firebox. Does this effect the amount of wood used or shorten the burn times? I have no experience with PE stoves. Love the looks, but I don't know what to expect from them.
Does it lock in to a temperature well?
Basic needs for the stove:
I need a stove that I can set in and not worry about it (much).
Long Burn times. At least 8 hours of good temps. Preferable 10 hours. (outside temps obviously effect this, but you understand)
I'm avoiding a cat stove on this go around due to my experience with the Intrepid. I will probably try a Cat stove again when I replace the Vigilant in a few years, but right now my frustration outweighs the benefits of a cat stove.
