, I've determined that I generally need to add about 4% to the measured result when testing in the cold. If I'm of the mindset to get a truly accurate result, I bring one of the bigger splits inside for 24 hours, then take it out and immediately split and test.Concrete walls and floors can soak up damn near every last Btu of energy radiated from your stove. If that stove has a very high convective factor, such as iron-clad steel stoves with a convective jacket, then it's going to behave much better in a basement. But if it's just brick on a single wall steel or iron jacket, you're probably just experiencing the enormous heat sink we call "earth".
So, as @hilly said, "is the basement insulated"?
Magnehelic, pick 'em up used on ebay. Or any other gauge with graduations that'll let you see 0.01" WC increments. The magnehelic I use has a 0.25" WC full range, perfectly fine for seeing .05" nominal target.Where can I get a draft gauge or how can I go about measuring the draft?
You sure you're not mixing up threads stoveliker?Yes, correct and fair. But a previous stove here worked well. ( Though I'm not sure how the heat outputs compare.)
Too coarse, 2 psi is 55" WC. So even if it has 0.3% full range accuracy, that's still ±0.17" EOM. You're looking for something that can read .01" WC increments, or thereabouts.
