If you have the ductwork sized properly in the home. Stepped down to keep the pressure in the ducts, then you should be okay. The trick is, if feeding it into the plenum of the central furnace, you need a damper or a diffuser so it doesn't backfeed into the central furnace. This keeps your pressure up in the lines so the heat can push through the trunk, through the ducts. You will keep pressure till it starts to hit those open ducts. You will of course lose some heat at the end, but with a 1400 cfm blower, and your trunk from your wood furnace. I think it would work.
