Do I have to brush can I just put some more creosote remover in one more night my back is in a lot of pain just don't know if I have it in me today.
			My primary air was open all the way.Open the primary air up alittle more.
That happens to me when I have the combustors engaged and the draft slides open too much. I have to either open the damper some or close the draft slides some. My combustors are worn out/blocked up. Stan, I have the Appalachian 32B built early 80's. Our stoves are probably very similar.I am done with the wood stove for the year. I will try again next year. I will buy the telescoping double wall stove pipe and cat probe.
 I guess I missed that and was thinking probe temp! My top prolly never gets over 350ishYes the wood I had was not dry so I bought some wood from FL. But I just got some maple that has been standing dead for a long that just right.I can only guess the you bought FL Wood because what you had was not dry
If you look at the smoke coming out before you engage, then after, there should be less or no smoke if the cat is burning.Look like the cat are burning the gases off.
You'll have to see about the Maple when you burn it. I would throw only a split or two on a good coal bed; If moisture sizzles or bubbles out the end of the splits, obviously they aren't dry enough. In that case you could mix in some of the FL wood to get it burning better. For sure, get some of that dead standing stuff split and stacked, and start building up the bank for next season.Yes the wood I had was not dry so I bought some wood from FL. But I just got some maple that has been standing dead for a long that just right.
I will put 8 split in tonight to see how that works.
But need to figure out how to get a better draft in my warm climate.
You have a surface thermo on the pipe, single-wall stove pipe, correct? At 18" above the stove top, I don't think you want to get it above 500* or so, as the internal temp will be double that, probably getting close to the pipe rating for sustained temp. Some others that know more may chime in on this. As far as your stove top temp, is there an air space between the top of the stove and the actual top of the fire box (a space that the blower air passes through?) If so, 475 on the outer shell is pretty damn hot, I would think. The actual stove top temp is much higher than that if there's an air space between it and the shell...How hot should I get the stove pipe and for how long?
There is a space but its like a step up and thermo is setting on the lower step which is the firebox.(a space that the blower air passes through?)
 Its 86* and the stove is out.We use essential cookies to make this site work, and optional cookies to enhance your experience.
