When I bought my house approximately 1 year ago the 40 year old oil furnace was venting into a masonry (concrete block w/ clay flue) chimney. Also venting to the same flue was a Fisher? wood stove. After having a professional chimney sweep come in they recommended removing the woodstove from the setup. So we removed the woodstove and ran just the furnace vent into the chimney.
Flash forward a year and I have replaced the oil-burning furnace with a direct vent lp furnace. This frees up the masonry chimney to be used to vent the woodstove I disconnect the prior year. The stove pipe for the woodstove is all 8" but the inside diameter of the clay thimble is only 7 1/2". Is this common? Do I need to have something fabricated to accept an 8" stove pipe on one end and reduce down to 7 1/2 " on the other end to fit into the thimble? Or is there a common adapter out there for this?
The one side of the chimney that has the thimble is also faced w/brick. The thimble is recessed into the brick and that opening is 9". This again leads me to believe I am missing a piece of stove pipe that would fit into the thimble and that accepts the 8" stove pipe. Unfortunately I was not paying attention and either the chimney sweep, the installers for the lp furnace, or more than likely I tossed this magical piece of metal.
Any help on what this adapter would be called or what I need to make this work is greatly appreciated. Thanks!
