D
DexterDay
Guest
Swing setting? is this the same as "Span time"???
On my new stat, there is a span setting. the default is 2, which means that the system will cycle on or off when the temp is within 1 degree of the set temp.
Some are slightly different. But yes, its the same. Some just use term differently or use the # of degrees differently..
Example : On my stat, at 2° swing, if set at 70°, will cycle the stat on at 68° and off at 72°… (2° each way from set point).
So it essentially is 4° difference. But I like a big swing. The stove runs longer. But stays off longer.
My Fahrenheit has a stat that has a swing thats different. If its set at 70° and I have a 2° swing/span. It comes on at 68° and off at 70°… So its really only 2°
